Numerical Constant to Audio Wave
Page 1 of 1 [9 Posts]
dualphin
G2 patch files: 4
PostPosted: Fri Feb 01, 2008 5:19 pm    Post subject: Numerical Constant to Audio Wave Reply with quote  Mark this post and the followings unread
Here are two patches:
They convert a numerical constant into a 64-step audio waveform.
In the first patch, the lowest place (ones) in the AD converter are checked most frequently, and the highest place (64) is checked least frequently.
In the second patch, the highest place (64) from the AD converter is checked most frequently, and the lowest (1) is checked least.
This results in different sounds when they are swept.
I have included in each case a switch to select between a constant and swept value.
I have not figured out how to deal with the negative sign--it could be used perhaps to create 128-step waves. I also have no idea what these waveforms look like.
Would welcome some input. I know very little about digital logic.
dualphin
Value to wave2--highs dominate.pch2
 Filename:  Value to wave2--highs dominate.pch2
 Filesize:  1.46 KB
 Downloaded:  1933 Time(s)
Value to wave.pch2
 Filename:  Value to wave.pch2
 Filesize:  1.46 KB
 Downloaded:  1940 Time(s)
dualphin
G2 patch files: 4
PostPosted: Fri Feb 01, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
My intent here is to be able to generate waveforms from the mod wheel. There are a lot of other ideas I have about generating waveforms from digital conversions of numbers--but it is going to take a while to figure them out.
dualphin
Audio files: 297
PostPosted: Fri Feb 01, 2008 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those are fun patches !
Audio files: 297
PostPosted: Fri Feb 01, 2008 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I mean I just toyed with it and variations on it for several hours Laughing
Audio files: 297
PostPosted: Sat Feb 02, 2008 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a noodly thingy I made with it
value_to_wave2_highs_dominate_noodly_08.pch2
 Filename:  value_to_wave2_highs_dominate_noodly_08.pch2
 Filesize:  3.34 KB
 Downloaded:  2701 Time(s)
dualphin
G2 patch files: 4
PostPosted: Wed Feb 06, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check out the ValWave patch I made-- it is in the Completed Synth Patches section. It is a fuller implementation of this patch.
And thank you for the kind words, Blue Hell.
dualphin!
Heaven is not attained, it is built -
Audio files: 297
PostPosted: Wed Feb 06, 2008 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did check it out, but somehow the words ended up here Laughing
That one you link to was a fun one as well.
dualphin
G2 patch files: 4
PostPosted: Wed Feb 06, 2008 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the latest version. More modulation capabilities.
ValWaveSynth.pch2
 Filename:  ValWaveSynth.pch2
 Filesize:  2.34 KB
 Downloaded:  1854 Time(s)
dualphin!
dualphin
G2 patch files: 4
PostPosted: Wed Feb 06, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell,
Your patch is very alive sounding.
Sometimes when the formants/filters open way up, it gets an ARP-y sound. Also. when it jumps quickly from note to note, that sounds quite pleasant.
dualphin
