nl3 synched noise on g2?
Page 1 of 1 [5 Posts]
suthnear
PostPosted: Fri Feb 15, 2008 11:58 am    Post subject: nl3 synched noise on g2? Reply with quote  Mark this post and the followings unread
hi,
is it possible to create the nordlead 3 synched noise on the g2? tbh, I'm not sure what it's doing so I have no idea how to patch something like this. The manual says the following:
"This will produce very special signals with non-transposed formant spectrum with strong “body resonance” characteristics. The reason ‘synched noise’ works at all is that it’s the same series of frequencies that are synched (repeated over and over). "
I've had a search and can't find anything here so hopefully the first response won't be a link to another discussion Smile
t.i.a.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Feb 15, 2008 4:28 pm    Post subject: Re: nl3 synched noise on g2? Reply with quote  Mark this post and the followings unread
I think it is equal to driving a RndClk module with a fixed high frequency, and feeding a regular tracking oscillator into the Rst input. The constant level at the seed input sets the wave shape.
The result doesn't sound like noise though. I think on the classic it was called a formant oscillator (a better name).
Here is a demo patch.
synchedNoise.pch2
 Filename:  synchedNoise.pch2
 Filesize:  1.38 KB
 Downloaded:  2216 Time(s)
Audio files: 309
PostPosted: Fri Feb 15, 2008 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny, I was working on the same idea with basically the same patch, except that I used the random pattern generator and made the variations in wave shape stepwise with the A and B inputs. But I got distracted a bit ... the thing went noodly on me .. anyway, a variation on the idea.
08-005-033.pch2
 Filename:  08-005-033.pch2
 Filesize:  3.04 KB
 Downloaded:  2946 Time(s)
suthnear
PostPosted: Fri Feb 15, 2008 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
you guys rock! thanks so much
Rokatansky
PostPosted: Thu Jan 27, 2011 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was trying to get this "Synched Noise" from the NL3-NL2 too.
Since i own a NL3 i was able to compare the real stuff and got a more similar sound with a hi (96%) pw saw oscillator sended to the pitch shifter.
So at the end i believe that the "Synched Noise" has more to do with a ring modulated oscillator than noise at all.
Now i need to figure out how to add the "stepped" harmonics knob.
