Eagle Question
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
Clack
PostPosted: Mon Mar 24, 2008 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
yes it tends to do that - eagle isnt perfect! ( far from it in many cases ) it kind of needs to be re-drawn
im working on fixing that library at the moment
Clacktronics.co.uk
Clack
PostPosted: Mon Mar 24, 2008 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
here we go
its just a case of changing the grid sizes till they meet the placement of the pin
I have also added the following to it
LM386
Alpha pot ( still needs a little work )
synthdiy updated imperial.rar
 Filename:  synthdiy updated imperial.rar
 Filesize:  9.82 KB
 Downloaded:  362 Time(s)
Clacktronics.co.uk
Sound
PostPosted: Mon Mar 24, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
thousand thanks! Very Happy the CA3080E works fine!
but... how you did it?
Clack
PostPosted: Mon Mar 24, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
the person that first drew the library had it set on very fine grid setting - ju8st changed the alt gird setting ( when you press alt ) to 4th of .01" and moved them to the nearest .01" line - its nothing to do with being imperial or metric i realise!
Clacktronics.co.uk
Sound
PostPosted: Mon Mar 24, 2008 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understood.
Well I just have did the schematics of serge VCA from Marjan Urekar. But when I swap to board layout the Pcb layout not is ready. Look at the picture.
When I click in "auto" It says that "the light eagle can't perform the requested action".
So What I need for from a schematics do an automatic PCB layout? Do I need the standard eagle? http://www.cadsoft.de/prices.htm . What do you do?
 Filesize:  141.58 KB
 Viewed:  285 Time(s)
SCHEMATICS.zip
 Filename:  SCHEMATICS.zip
 Filesize:  27.96 KB
 Downloaded:  209 Time(s)
Clack
PostPosted: Mon Mar 24, 2008 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
im afraid you cant auto layout the parts, auto is for autorouter meaning it will find the best possible route between parts for you. you need to place the parts first inside the white square area
The free version of eagle only allows you to put parts inside that white square
i got myself started out on this tutorial
http://myhome.spu.edu/bolding/EE4211/EagleTutorial4.htm
and this
http://vulcan.ece.ucsb.edu/ece189/tutorial1board.html
Clacktronics.co.uk
Sound
PostPosted: Tue Mar 25, 2008 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
and this
J aj aj! but my idea was good! Thanks very much for the links.
