using eq as an effect?
Page 1 of 1 [4 Posts]
Helpless
PostPosted: Tue Apr 01, 2008 9:48 am    Post subject: using eq as an effect? Reply with quote  Mark this post and the followings unread
hey lately on some of my samples,particularly dronies,i've been playing around more and more with eq levels to give them a dustier sound,which is
what i want
is it wise to be using eq as an effect or is it going to come back and bite me?
Kassen
PostPosted: Tue Apr 01, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
You'll be fine. EQ is no worse or better then other filtering (which it is). Of course it can bite you in some cases but this usage is perfectly normal and fine.
Kassen
Sam_Zen
PostPosted: Tue Apr 01, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using the term "effect" has become a little fuzzy in the course of time.
It often is related to things like distortion, reverb, flanging, etc. With maybe a negative imago of a 'cheap trick'.
I think, strictly spoken, that any modulation of some original sound-source can be seen as 'applying an effect'.
So also an equalizer. Nothing wrong with bending your material the way you want it to be.
I use samples a lot in my work too, and I always will consider them as "raw material".
Kassen
PostPosted: Tue Apr 01, 2008 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
As with many things; it only sounds cheap if you consciously notice it :¬)
Kassen
