Square to sawtooth waveform conversion?
Page 1 of 2 [26 Posts]
Peake
PostPosted: Wed Apr 09, 2008 11:35 am    Post subject: Square to sawtooth waveform conversion?
Subject description: I want to get more mileage out of suboctaves
Hi, Google hath failed me Smile
I want to add a suboctave module to my system, and want more than a square or pulse waveform. Was it Fritz who posted a sine suboctave generator? Does anyone have a circuit for square to saw conversion?
Thanks..
françois
PostPosted: Wed Apr 09, 2008 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Generating a sawtooth from a square is not possible since the square has lost almost all time information. OTOH, making a sine is possible by filtering out all the harmonics.
I posted here some weeks (or was it months ?) ago a topic on how to generate sub-octave and super-octave sawtooths (and also ×3, ×5, ÷3 and ÷5 frequencies). I'll try to find it.
EDIT: here it is :
http://electro-music.com/forum/topic-22679.html
Yours,
-- françois
bubblechamber
PostPosted: Wed Apr 09, 2008 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, if you convert your Square to a Triangle, you can use them both to create a Saw using the EN#129 waveshaper...
françois
PostPosted: Wed Apr 09, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed. The only problem is that a triangle is as impossible to get from a square as a sawtooth is.
Of course, if you let your square wave go through an integrator, you do get a triangle wave. But its amplitude will change with the frequency of the square wave, a most undesirable feature I think.
-- françois
G2 patch files: 626
PostPosted: Wed Apr 09, 2008 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can get a 75% pulse by ORing divide by 2 and divide by 4. This is close to a saw harmonically. Roland do it on some of their synths.
bubblechamber
PostPosted: Wed Apr 09, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
-- françois
and I think it's an inverse relationship so that the higher the frequency the lower the amplitude.
there is a sawtooth generator in the op amp cookbook, fig 7-25 in my copy, that might do the trick. it runs off a Square input so your suboct Square should work as the trigger. if you need a scan let me know and I'll post it... looks very simple. if I have the time over the next day or 2 I'll breadboard it and see how it works.
d
Peake
PostPosted: Wed Apr 09, 2008 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for all of the replies. Yes, please scan it and post away. I appreciate it and it might create a bit of interest.
françois
PostPosted: Thu Apr 10, 2008 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I'd like to see it too. I have so many documents entitled "Opamp Cookbook" or something similar, I can't guess which one you are referring to... and it might be I miss this one !
Attached is a sawtooth suboctave generator. Input is a raising sawtooth (from -5V to +5V) and a train of sync (CLK) pulses, as are available from any ASM-1 type VCO core. Output is an inverted sawtooth at half the frequency.
Yours,
-- françois
Visio-Sawtooth Suboctave.pdf
 Filename:  Visio-Sawtooth Suboctave.pdf
 Filesize:  6.15 KB
 Downloaded:  827 Time(s)
richardc64
Audio files: 26
PostPosted: Thu Apr 10, 2008 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
http://home.comcast.net/~sbernardi/elec/og2/og3_sine_suboctave.html
sneakthief
PostPosted: Thu Apr 10, 2008 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
for your edification, i suggest that you read this thread if you haven't already:
http://electro-music.com/forum/topic-23058.html
Sneak-Thief - raw electrofunk
françois
PostPosted: Thu Apr 10, 2008 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting, and very similar to my design. The ony differnce is that mine was only SPICE tested, not even breadboarded... But even so, it has glitches (spikes) at every reset of the input saw. These are normally not audible, but can be removed (to a large amound) by adding a small (say, 100p) cap across the feedback resistore at U1.
-- françois
Funky40
G2 patch files: 5
PostPosted: Thu Apr 10, 2008 5:51 am    Post subject: Re: Square to sawtooth waveform conversion?
Thanks..
the Modul fcrom Scott Bernardi delivers Sine, saw, and Square suboctaves.
It must be feed with Sawwaves.
I just opened a Thread for this Module:
http://www.electro-music.com/forum/post-179578.html#179578
here the link to Scott B' site: ( schematic is on the Bottom )
bubblechamber
PostPosted: Thu Apr 10, 2008 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is from Jung's Op Amp Cookbook. it doesn't look prefect, but it does look easy...
 Filesize:  214.39 KB
 Viewed:  285 Time(s)
françois
PostPosted: Fri Apr 11, 2008 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you !
I must have a deeper look on this circuit, but at first view I doubt it will convert a square into a saw at the same frequency. It seems to be just a synchronized sawtooth generator. But I'm not really sure, I'll have a really torough analysis before I can say more.
BTW, which book did you get this from ? I've not seen it in any of mine, so I must have missed one of the (very many) refverence book around there...
-- françois
yusynth
PostPosted: Fri Apr 11, 2008 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
This schematic is based on what is called a TAC for Time to Amplitude Converter, this is used to measure a time delay between two events or convert a frequency into a CV. This is not what you expect, the slope of the generated ramp is constant (adjustable by the potentiometer R5). Therefore, if you apply a rectangular signal to the inputs then you will get a ramp of constant slope and variable amplitude depending on the input frequency. You would have to change the value of R5 in phase with the input frequency...
Yves
Clack
PostPosted: Fri Apr 11, 2008 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
would it be possible to do ? with another frequency to volt converter? I imagine it would be pretty hard to sync. but possible?
This kind of thing would be ideal for a F multiplier too as a sawtooth can be split with comparators.
Clacktronics.co.uk
yusynth
PostPosted: Fri Apr 11, 2008 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it would, but that would be poorly efficient. If you have TAC like here you can easily extract the average amplitude of the sawtooth and use this voltage to drive a sawtooth linear VCO.
Yves
bubblechamber
PostPosted: Fri Apr 11, 2008 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
-- françois
it's from Walter Jung's IC Op Amp Cookbook. I seem to have a first edition, so maybe this was left out in later versions. there might be something in the 555 timer cookbook I have. I'll look through these over the weekend. this is something I'm pretty interested in too.
françois
PostPosted: Sat Apr 12, 2008 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, this one ? I should have thought of it at first glance. I don't have it, but it is quoted every here and there as a "classic". I think I'll buy it, I had a look at Amazon, it is not really expensive (around US$40, i.e. €30).
Thanks !
-- françois
Danno Gee Ray
PostPosted: Sun Apr 13, 2008 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the third edition of that book and in mine, the figure is now "Fig. 10-24" and is found on page 492.
JovianPyx
Audio files: 224
PostPosted: Mon Apr 14, 2008 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Some years ago, someone sent me a schematic for a square to saw (or perhaps square to tri) circuit. It was based on successive approximation, but the wave would quickly evolve when the input changed frequency.
Unfortunately, I am not at liberty to reveal the schematic, I promised not to do that.
Time flies like a banana.
corruptio optimi pessima
jhaible
PostPosted: Mon Apr 14, 2008 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anybody mentioned the old Korg trick to create Saw suboctaves?
You start with a saw in the highest octave, then divide down the frequency with flipflops to get the lower octaves, all in square wave form.
Then you build starcase waveforms from weighted squares of the required octave, and all higher octaves.
And finally, you fill the gaps of this staircase with the saw wave from the highest octave.
Voila, saw wave in every sub octave.
Many old Korg synths did this:
Minikorg, Maxikorg, PS-3100 (and if memory serves, the Polysix as well).
This was mainly used for creating the "normal" oscillator signal in different transpositions rather than for dedicated suboctave generators.
I've used this method in the JH-720, whose VCO was inspired by the Minikorg 700:
http://home.debitel.net/user/jhaible/jh_720_vco_core.gif
JH.
(wondering if it makes sense to ffer some old style Korg synth PCBs at one time - there's a lot of interesing stuff burried in old Korg's - "singing" envelope, anybody? Smile )
Peake
PostPosted: Mon Apr 14, 2008 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
That rings a bell- wasn't the SH7 something similar to that Korg design? It would be interesting to have that with mixing versus switching.
jhaible
PostPosted: Mon Apr 14, 2008 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the SH7 has two VCOs (x2), with one sync'ed to the other. (Long time since I checked - forgot what has been the goal behind that - but it's certainly a different method from Korg's)
JH.
gavgomad
PostPosted: Mon Apr 14, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, the ol' Korg "singing" envelope.... Memories of my ol' maxi-korg that I sold many years ago. Unique instrument, although there were elements of the design that were SO foreign to me that I could never really tell if the synth was actually working to spec, or just "freaking out" - the "Repeat" circuit, for example.... Never understood those modes! ;-P
Gavin.
