<on air> Twyndyllyngs - not canceled Chez Mosc
KLEE came to live...
Page 1 of 2 [38 Posts]
PostPosted: Wed Apr 23, 2008 11:45 pm    Post subject: KLEE came to live...
Subject description: ..a green field of clover...
<wiseheimer>
Klee (germ.) = clover
<wiseheimer>
yesterday night my klee2 came to live finally! it took too long, i know. i followed the development of the klee from the beginning in the original thread. my panel still reflects the design of the first panel layout i designed for the original thread back in ... err... 2006? not sure.
however i powered it up yesterday, and as far as i can see for now, everything's working fine (mixed trigger with gate, glide potentiometers work reversed and some other wiring related issues, though). the range selector is not wired yet and the midi2trigger board is finished but not installed yet.
after playing around for 10min i must admit to love it. again cheerios to scott and the klee-team-members...
klee2_02
klee2_01
PostPosted: Wed Apr 23, 2008 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful job Fonik! Very Happy
ACHTUNG!
xpmtl
PostPosted: Thu Apr 24, 2008 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed very nice!
Did u build the Papareil Midi to Clock finally or is it another design?
Fred
http://sdiy.xpmtl.net
PostPosted: Thu Apr 24, 2008 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
xpmtl wrote:
Indeed very nice!
Fred
i built marc papareils midi2clock. low part count and i could test/try my pic programmer. i also made a mixer map for cubase5, so i can control it from within the software.
i got a midibox pcb and pic in my drawer. i will try that later. i just wanted to have my klee2 midi triggerable ASAP.
softfin
PostPosted: Thu Apr 24, 2008 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations Fonik! That's definately a great looking Klee.
Makes me think I really should begin building my own Klee soon as well. Just been having a break from all things electronic and concentrating on other things...
RF
Audio files: 28
PostPosted: Thu Apr 24, 2008 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik - As usual, that's a beautiful job. Congrats!
Like you, I just moved - so I'm living out of boxes...I have no idea how you got this done so soon after your move Shocked
Bruce
PostPosted: Thu Apr 24, 2008 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Bruce
Laughing
the panel has been finished before the PCBs were available. i started building the klee's electronics right when the 1st run PCBs arrived, so i had to finish the wiring only.
now living in a house, not a flat, i got a room in the basement just for my synth-DIY. that helps a lot. if i want to do something, everyhting is ready to use, if i want to stop building i can just leave everything as is and close the door. that's great.
BTW thank you guys for your kind feedback!
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Apr 24, 2008 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
very pro looking. like all your work.
congratz!!
really nice.
PostPosted: Thu Apr 24, 2008 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I would expect nothing less from Mr Fonik! Cool
Sound
PostPosted: Thu Apr 24, 2008 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik Very Happy could you explain it a little bit more?
It is an amazing Klee, congratulations!
funkyfarm
PostPosted: Thu Apr 24, 2008 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pouah !
what a piece of panel !
Is this 6mm LED ? you ought to get big led for this kind of big panel, right ?
("cubase mixermap" reminds me my old atari STE. Very Happy )
PostPosted: Thu Apr 24, 2008 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
@sound
for actuall music production i still use cubase5 (too late for me to upgrade and i recently bought ableton). in cubase5 you can build user interfaces with knobs, sliders and other controls that communicate with your midi gear via sysex, and assign them to a certain track.
@funkyfarm
thank you Embarassed
these are common green 3mm low current LEDs with black anodized LED holders. the 1st, 5th, 9th and 13th step is yellow to reflect the 4step idea from the original KLEE...
Scott Stites
Audio files: 96
PostPosted: Fri Apr 25, 2008 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You were the only builder that had an illustration of your panel in the build doc Laughing
Beautiful work, Mr. Fonik, my hat's off to you!!!
Scott
My Site
loopcycle
PostPosted: Sat Apr 26, 2008 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
awesome looking klee! id like to see it in action.
plord
PostPosted: Thu May 01, 2008 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik,
That looks great and is a great inspiration for my own plans. Can you tell me, what is the case/housing behind your panel? is that a Schaeffer/FPD panel or was it created by other means to fit the case?
PostPosted: Thu May 01, 2008 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
plord wrote:
fonik,
yes. it is a schaeffer panel i used to replace the frontpanel of this cabinet: rs components multipac. i couldn't find it on the northamerican rs-components (allied components) site, though.
Kartoshka
PostPosted: Sat May 03, 2008 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
2 questions from my side:
a) Papareil MIDI to CV-Gate Interface MC-628?
b) which PSU circuit is installed inside, fonik? ....
(btw) i really like your panel design. Embarassed
PostPosted: Sun May 04, 2008 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, it's marc barreilles 628.
currently i am using a crappy noisy cheap switching PSU, it is almost unusable. i just got the parts for ken stones audio PSU.
sneakthief
PostPosted: Mon May 05, 2008 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
how much did that schaeffer panel cost? and are those 30mm sliders?
vielen Dank!
Sneak-Thief - raw electrofunk
sneakthief
PostPosted: Mon May 05, 2008 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm glad that the other guy's post after my last one was deleted. there seemed to be a misunderstanding about fonik's answer to the psu question - the snarky response was definitely not merited.
to clarify, fonik bought a cheap 3euro switching psu from pollin.de: http://electro-music.com/forum/viewtopic.php?highlight=pollin&t=17726
i recognized it in the klee pic Smile but it doesn't sound like it worked very well... not that surprising for that price Razz
so he instead bought a cgs psu board. hope that clears everything up.
PostPosted: Mon May 05, 2008 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
vielen Dank!
yep, i used 30mm alpha sliders from futurlec.com. work fine.
the panel was about 115.-EUR.
PostPosted: Mon May 05, 2008 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
did not see this certain post.
thank you sneakthief for clarification.
however, yesterday i tried the klee together with my EFM dual VCOs instead of the TH 3038 dual VCOs, and i could not recognize the noise anymore?!
i will build and incorporate ken stones PSU, though.
Kartoshka
PostPosted: Tue May 06, 2008 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
it was me who posted and later deleted the post.
Snarky? Man, i said "thanks for advice".
Why i deleted it? i saw there's 2 Ken Stone's PSUs, one for music synthesizers CGS66 and the second general one, CGS14.
After posting the "it's probably CGS66 one, thanks for advice", i made a little research and came up with this..
i guess the answer is clear Rolling Eyes
Thanks for pointing the CGS66 out, anyways!
Kart
sneakthief
PostPosted: Tue May 06, 2008 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
on the post you deleted, you said "thanks for the advice" then put the "roll eyes" smiley.
that, my friend, is the snarky comment i was referring to. a "thanks" followed by Rolling Eyes is definitely sarcasm in the english-speaking world.
(i'm not from germany and english is my native language - so i wouldn't attribute this to a mistranslation language on my part)
Audio files: 299
PostPosted: Tue May 06, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
But as there are two sides when communication is going on it may still be the case that you read a meaning that was not implied Wink
