a question to cgs digital noise users
Page 1 of 1 [14 Posts]
synth_ollie
PostPosted: Tue May 20, 2008 12:50 pm    Post subject: a question to cgs digital noise users Reply with quote  Mark this post and the followings unread
do you ever use the wh/pnk trigger outputs ?
I have a very limited frontpanel space and it seems like I
will have to choose between the trigger outputs or the leds,
and its always nice with some visible indication so.... ?
cheers
OLLIE
andrewF
PostPosted: Tue May 20, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
for me, the digital outs get used more than the noise outs.
You could take the middle path, have one led and one digital out.
fluxmonkey
PostPosted: Tue May 20, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i use both filterd outs all the time... pnk out at slow clock settings to FM VCOs is particular fave. i wouldn't cut them. the 2 digital outs sound the same to me, so you might drop one; and i really don't think the LEDs provide much (i didn't implement them). also: don't omit the external CV and Clock ins... these are insanely useful.
b
Cat-A-Tonic
PostPosted: Tue May 20, 2008 7:00 pm    Post subject: digital noise
Subject description: digital noise
Agreed, you don't need LEDs just jack up everything.
CV in, Clock in, pink, white, 2x digital, rate knob.
Fits in a single size Frac panel.
I love sending one channel of the Dual Drum to the Klangwerk, Using the White noise as a carrier (ext. freq), and the Digital noise as the CV for the carrier wave. Perfect Snare Drum.
zthee
PostPosted: Tue May 20, 2008 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, this thread was really usefull. As I just ordered me a digital noise pcb!
otherunicorn
PostPosted: Wed May 21, 2008 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
b
The two digital outputs do sound the same. If you are going to have just one, either is as good as the other. The purpose of having two is for when you want to use both at once - then the difference is of some value.
http://www.cgs.synth.net/
synth_ollie
PostPosted: Wed May 21, 2008 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks all for your replies Smile
I think I´ll go for one dig. out and one led
cheers
OLLIE
PostPosted: Wed May 21, 2008 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW, smallest (non SMD) LEDs currently available seem to be 1.8 mm, although maybe not so easy to find.
synth_ollie
PostPosted: Sun May 25, 2008 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
well, it was really more a question of how I would use the
number of pre drilled holes on the panel the best way
I have replaced the ordinary noise gen. in one of my
m-150 (roland 100m) modules with a cgs digital noise,
here´s how it finally turned out
edit: a short soundclip sweeping/modulating the int. clock
http://www.analogue.org/roland100m.ce/media/dng.mp3
etaoin
PostPosted: Sat May 31, 2008 3:37 am    Post subject: Re: digital noise
Indeed. It even fits in a single size Frac with 5mm LEDs.
Check:
http://www.casia.org/modular/img/casia_ms01_080305.jpg
Top row, fifth module from the left.
synthetic
PostPosted: Mon Jun 02, 2008 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the MP3, I was wondering what this thing sounded like. Now I know – every videogame I played from 1985-89.
zthee
PostPosted: Tue Jun 03, 2008 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I jused finished my module! Yay!
Sounds great! (As great as noise can sound Smile ).
http://zthee.vantage.ch/31.mp3
Solid Rate Studios
PostPosted: Thu Jun 05, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
My opinion on the CGS Digital Noise... It's a great Noise source, for sure! But, it's also a great random trigger out x3 when synced to an external clock! Try it, you'll like it!!!
-dJ dAb
CGS PSYCHO LFO / 2 RADIO SHACK LO-FI SAMPLERS / CGS DIGITAL NOISE
FULL RACK
Sine
PostPosted: Fri Jun 06, 2008 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooohhh ....
Now I am going to HAVE to get me one of those !
And I'm already low on free rack space ... O well Razz
