Wishes for new Boards
Page 1 of 1 [17 Posts]
Funky40
G2 patch files: 5
PostPosted: Sat Jul 12, 2008 12:20 pm    Post subject: Wishes for new Boards Reply with quote  Mark this post and the followings unread
Hello Ken,
i wish to have a Sequential switch like the CGS-28 but with 16stages.
many uses for it !
For example switching between envelopes.
Or building Sequenzers out of it.
With buffered outputs one could make big trigger sequenzers in conjuncton with a CGS 28, or even with two 16step Babys.
For me, Music beginns with 16steps = 1 Bar.
when having two Bars it begins to be groovy.
working with 16step stuff is much more easy.
16step Sequential switches are a need for me.
Hopefully for others too.
Please feel free to post your own wishes,
or to double my one Wink
jnuaury
Audio files: 9
PostPosted: Sat Jul 12, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
well i dont think many people need the extra 8 steps...
but if you really want to go that route you could al;ways replace the 4051s with a 16 channel mux/demux like the 4067
the 4516 counter ken uses is 4-bit so you shouldnt need to sub out that chip just make use of the extra bit
and of course this circuit wont fit on the 8 channel board
Rykhaard
PostPosted: Sat Jul 12, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
My wish is a little more complex along the X and Y axii. Wink
Since I haven't ever seen anywhere, a sequencer engine that you may assign the output BITs TO, I'm in the middle of building mine, right now. Ken Stone's new Master Divider version (2 of them) are now to become part of it, for clock divisions as well as phase changes. (90º, 180º, 270º and normal).
My new engine will allow me to assign counts to different sets of sequencers that have their step #'s controllable by bit selection.
To try and make this clearer in English, let me diagram it:
- Let's say that I have 4 x 4 step sequencers. I'll depict them this way:
x = step OFF
X = step ON
I might have (in the future) them set up in a panel like this:
xxxx
xxxx
xxxx
xxxx
With my sequencer engine (that sends out the bits to be played, I could then patch it together so that the above shown 16 steps play in this sequential order:
(The #'s at the top give a step reference #.)
1... 2... 3... 4...
Xxxx xXxx xxXx xxxX
xxxx xxxx xxxx xxxx
xxxx xxxx xxxx xxxx
xxxx xxxx xxxx xxxx
5... 6... 7... 8...
xxxx xxxx xxxx xxxx
Xxxx xXxx xxXx xxxX
xxxx xxxx xxxx xxxx
xxxx xxxx xxxx xxxx
etc. down through to this:
13.. 14.. 15.. 16..
xxxx xxxx xxxx xxxx
xxxx xxxx xxxx xxxx
xxxx xxxx xxxx xxxx
Xxxx xXxx xxXx xxxX
and then start over.
Or, I could have them patched to play in this fashion
1... 5... 9... 13..
Xxxx xxxx xxxx xxxx
xXxx xxxx xxxx xxxx
xxXx xxxx xxxx xxxx
xxxX xxxx xxxx xxxx
1... 5... 9... 13..
xxxx Xxxx xxxx xxxx
xxxx xXxx xxxx xxxx
xxxx xxXx xxxx xxxx
xxxx xxxX xxxx xxxx
through to this
1... 5... 9... 13..
xxxx xxxx xxxx Xxxx
xxxx xxxx xxxx xXxx
xxxx xxxx xxxx xxXx
xxxx xxxx xxxx xxxX
and then repeat over
Or - any variations of steps, through the 4 sets of 4 step sequencers.
The differences in sequences potential for this, is astounding! Shocked It's taken me 2 1/2 of years of on/off building, to finally get my panel and PCBs started for it. Though - I've had 1 of my wished for 4, 4 step sequencers completed since November. I hope to have the sequencer engine completed within the next couple of weeks. Once I do, I'll post videos on my site to give a better idea of it all. Smile
My WISH anyways - is to have a sequencer engine, that allows the user greater control of what groupings of notes will play when; how; etc., rather than having the same 8 or 16 notes looping over and over and over and ...... Wink
To finalize just in case: I'm also NOT looking for a computer sequencer that has to be controlled with a mouse / etc. Knobs, switches and cables and I'm happy. Smile
neandrewthal
PostPosted: Sun Jul 13, 2008 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Well there seems to be a lot of sergespiration behind CGS modules, so I wish for a Stonified update of the USG Cool
ericcoleridge
PostPosted: Sun Jul 13, 2008 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, a USG and a Wilson Analog Delay. And if someone's taking requests, a Pitch to Voltage Convertor.
Rykhaard
PostPosted: Sun Jul 13, 2008 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of my other biggest wishes at the mo', is for development on the new percussion module of Thomas Henry's design, to be finalized, so that I can order a couple or three. Smile Shocked Very Happy
Funky40
G2 patch files: 5
PostPosted: Mon Jul 14, 2008 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
another wish to Ken:
2 wishes, maybe both in one handy modul:
--------> CV Control of start/Stopp for External clocks going to Seqeunzers
----> and: gate to trigger with PWM for 4017 Style Sequenzers
please: vote for that one Wink
there are threads with some drawings of schematics alltready,
but i don't understand them enough.
1. ) Start/stopping (External) Clocks
http://www.electro-music.com/forum/topic-26532.html
2.) Something like Gate to Trigger, but with PWM .
http://www.electro-music.com/forum/post-188284.html#188284
fluxmonkey
PostPosted: Mon Jul 14, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
fmpov, th biggest gap in the catgirl catalog is an envelope generator. i know an ADSR has been on the drawing table for a while, which would be cool... tho i'd actually prefer a VC AR...
also would like to see a cleanup of the minor kludges on the VCO, but that's 'cause i'm lazy.
b
www.fluxmonkey.com
Luka
PostPosted: Mon Jul 14, 2008 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
what are they?
problemchild
melbourne australia
Dave Kendall
PostPosted: Wed Jul 16, 2008 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
FWIW, I'd love a VC ADSR. AFAIK, there isn't a cheap/ affordable PCB around for one, and EGs are always useful. If it's easy to have, VC control of say decay/release is great fun. Try slightly modulating decay with a triangle wave LFO and arpeggiating the result..... Smile
Luka
PostPosted: Wed Jul 16, 2008 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
perhaps a 16 stage gate SEQ with a CV ADR per stage
problemchild
melbourne australia
fluxmonkey
PostPosted: Thu Jul 17, 2008 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
oakely has a nice one
www.fluxmonkey.com
Dave Kendall
PostPosted: Thu Jul 17, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
The Oakley unit looks superb indeed Smile , but at £42 UKP including the THAT2180 VCA IC for the VC version it's sadly, way beyond my means......
Luka
PostPosted: Thu Jul 17, 2008 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
there is a digisound80 VCADSR
http://www.digisound80.co.uk/digisound/modules/80-10/80-10.htm
no pcb on offer though
also
http://www.sowa.synth.net/modular/vcaddsr.html
problemchild
melbourne australia
guitarfool
PostPosted: Thu Jul 17, 2008 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave Kendall wrote:
Hi.
Marc Bareille has a _dual_ VCADSR board for 32 euros:
http://m.bareille.free.fr/synth.htm
No exotic (or expensive) parts, either. I have several of them and they are good.
ericcoleridge
PostPosted: Wed Jul 23, 2008 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made this digisound module, with press'n'peel. Just had to re-size and invert. The first digisound module I made, the VCO, I didn't realize the image had to be inverted!!! I really blew it!!... the curtis chip that is!!! Still pissed about that. It's definitely my worst DIY disaster, that chip was at least $30.
But my digi VC ADSR works well. It's actually more like a VC DADSR. Haven't put it behind a panel yet. So many options to consider on this one.
Main cost is the chip, obviously, but besides that, there's not too much else to worry about.
Peake
PostPosted: Wed Jul 23, 2008 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps use a comparator (trig out to Start) and somehow (a second, linked comparator) for a trig out to Stop whenever the input signal is below the threshold? Could a Boolean solution work here?
