adamj
Joined: Jul 22, 2008 Posts: 3 Location: San Francisco
Posted: Tue Jul 22, 2008 3:44 pm Post subject:
different ways to sequence music Subject description: in need of some sequencing terminology |
I've lurked around these forums for a while. Definitely some interesting discussions going on. I need to bounce some ideas off other people, so here's my first post. Hello!
I spend a lot of time playing with different approaches to sequencing. I used to always think of sequencing in terms of the step sequencer / piano roll / tracker interfaces that are popular in a lot of software. These interfaces are all about placing notes and events within a timeline.
At some point I started making custom music software and it opened up my eyes to sequencing with no timeline. Each event is dependent on previous events instead of a higher level time structure. For example, instead of "play a note on beats 1 and 3 and 4", it's "play a note immediately, then 2 beats after that note, then 1 beat after that". In other words, timing is based on delays from the previous event.
Each sequencing approach has distinct strengths and weaknesses. For example, it's really easy to stop and restart a timeline-based sequence at an arbitrary time because there is a specific time when everything happens. Getting back to a "sync point" is trickier with the non-timeline approach. But with a non-timeline approach you can do some interesting things like inject extra beats into the sequence and really mess with rhythmic patterns on the fly.
I would like to explore these differences further and write about them. The issue is I don't really know how to talk about this stuff concisely. I need some terminology. I considered "absolute sequencing" and "relative sequencing", but I often use relative timelines within an absolute timeline, so those aren't good choices. Maybe "timeline sequencing" and "delay-based sequencing". I don't know...
So, does this make sense to anyone? Any thoughts on what terminology to use? Anyone else out there experimenting with non-timeline sequencing?
Adam
PS - If you want to hear some of my music you can find it over here: http://compusition.com/web/audio
I don't stick to any particular genre. The newest song is more upbeat electronic, the previous two are sorta classical, and a lot of the older stuff is pretty experimental. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Jul 22, 2008 4:25 pm Post subject:
adamj
In my view sequencing has always to do with a time line. I like the term 'relative' sequencing, which means a sound depends on the sound before using certain parameters. I have my doubts about 'absolute'. Maybe 'fixed'. Although, absolute/relative is a well known couple. 'Hybrid' as the mixed sequence?
Wout |
Posted: Wed Jul 23, 2008 11:16 am Post subject:
adamj!
Interesting thoughts. I often feel that the 16-step sequencer limits th possibilities for expression, though I like sequencing as such. It will be interesting to read further explanations about what you've found. i think relative and absolute will do as a starting point.
My own late experiments have concerned either skipping the quantised timeline completely - placing samples or events in a gridless environment - or messing with homemade arpeggiators. I'm not sure how sucessful this has been. Reading your post has put a couple more ideas in my head for something to try out on the monome.
Posted: Wed Jul 23, 2008 11:21 am Post subject:
BTW, nice tracks - I've listened to the top two so far.
Joined: Apr 03, 2004 Posts: 24500 Location: The Netherlands, Enschede
Posted: Wed Jul 23, 2008 12:19 pm Post subject:
I always start with the old ones, I liked what I heard there too. _________________ Jan
adamj
Posted: Wed Jul 23, 2008 5:00 pm Post subject:
Thanks for the replies.
I agree "relative sequencing" is a good way to describe it.
I like the suggestion of "fixed sequencing". I was avoiding "absolute" because that means something else to me. Say there's a basic drum pattern on beats 1,2,3,4. If I start playing that pattern on the second measure (4/4 time signature), I'd say there's a fixed sequence on beats 1,2,3,4 that starts at an offset time of 4 beats. The absolute time would be 5,6,7,8. The relative sequencing times would be 4,1,1,1 (or 0,1,1,1 with an offset of 4).
To sum up these ideas:
Absolute times are the offset from the start of the piece
Fixed times are the offset from the start of the subsequence (a motif or musical phrase or whatever)
Relative times are the offset from the start of the previous event
This is just slightly different ways of looking at the same thing: where in time does an event occur? (BTW, Wout you are right: all sequencing has a timeline, I just didn't know how to explain it).
I'm sure most of us switch perspective like this while writing music without necessarily realizing it. I haven't found any discussions of these different perspectives of time anywhere. If anyone can recommend some reading material that might be relevant, that would be awesome.
I believe forcing yourself to switch perspective has value because it can change the way you write music. I know that relative sequencing can make it easier to work with complex polyrhythms like 7,7,7... vs 13,13,13,... Try that with fixed sequencing, it's a pain! Most people probably wouldn't ever use rhythms like that in a traditional sequencer, because the representation of time limits them. |
Posted: Wed Jul 23, 2008 5:38 pm Post subject:
| adamj wrote: | To sum up these ideas:
Which would occur at multiple levels, so that also means that "absolute" is just a special case of fixed or a special case of relative rather as fixed is a special case of of relative in itself .... the piece as a whole is relative to the start time, then that has phrases starting relative to the start of the piece, where the phrases might have notes that should be played as a couple of notes in quick succession - don't know the english word for it, versiering in Dutch.
So I'd argue that one wouldn't need three different terms (given the right software/machinery of course, they would still be useful for describing less flexible arrangements).
| Quote: | | I know that relative sequencing can make it easier to work with complex polyrhythms like 7,7,7... vs 13,13,13,... Try that with fixed sequencing, it's a pain! |
Wouldn't be fun at all in a piano roll program. _________________ Jan
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 2073 Location: Berks County, PA
Audio files: 89
Posted: Wed Jul 23, 2008 5:54 pm Post subject:
The relative times seem to be an application of iterated function systems to meter.
| Quote: | | An iterated function or dynamical system is a function that is applied repeatedly, each time taking as argument its value at the previous application. |
Some people apply IFS to making noodles, although I haven't heard of it being applied to meter. Certainly seems like fertile ground  _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Wed Jul 23, 2008 7:54 pm Post subject:
More comments about sequencing later, but I have to say first, I just listened to "The Mirror" and I appreciate the harmonic variety very much. A whole lot of music gets locked into a chord progression and can't find its way into any neighboring territories, but clearly you catalogued some harmony variations and deployed them with careful pacing to keep things interesting.
I love love LOVE harmony and it's the thing I miss most about a lot of electronic music... people don't know their harmony. Not all electronic music obviously, but it seems like that's always the first to go...
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
plagal
Joined: Dec 28, 2007 Posts: 18 Location: South Carolina
Posted: Thu Jul 24, 2008 5:13 pm Post subject:
Re: different ways to sequence music Subject description: in need of some sequencing terminology |
| adamj wrote: | you can do some interesting things like inject extra beats into the sequence and really mess with rhythmic patterns on the fly.
Yes, I've been doing these sort of things with http://www.chordware.com
For example, while its playing, you can divide it into sections of corresponding lengths - then clicking a note on the keyboard graphic will inject the note at that instance, and for every section at corresponding points. Keep adding notes for complex arps.
Plus it does other rhythm and harmony changes on the fly...
BTW it doesn't use IFS, except for timer function calls. The changes take place either by applying math to timer calls, or changes to note-time values in the linked list when a control is clicked. |
adamj
Posted: Thu Jul 24, 2008 11:43 pm Post subject:
Blue Hell: yes, that's kind of what I meant when I said these are all slightly different ways of looking at the same thing. I had a realization: When we talk about time in music, we need to use a number, like this event happens 1 minute or 9 measures into the piece/section/phrase/whatever. Those numbers are meaningless unless you have a reference point. With fixed sequencing, the reference point is stationary. With relative sequencing it's constantly shifting. I think that's really the difference between these types of sequencing. The term "absolute" doesn't really apply when you look at it that way.
Acoustic Interloper and plagal: thanks for the links, they look very interesting. Might take a while to absorb.
James: I'm glad you noticed! I really, really love harmony too. One of the cools things about modern music software is almost anyone with the motivation can make music, but unfortunately there are many aspects of musical tradition that are lost on most people. Maybe it's because I had to write a lot of 4-part harmony in school, I usually start from chord progressions as the basis of a piece and go from there. Somewhere along the way I became too caught up in minimalism and used a lot of static harmony, but lately I've been trying to introduce more variation by modulating keys, etc. I'm happy with the results in "The Mirror" and hope I can take it further in future pieces. |
Acoustic Interloper
Audio files: 89
Posted: Sat Jul 26, 2008 8:00 pm Post subject:
| dewdrop_world wrote: | I love love LOVE harmony and it's the thing I miss most about a lot of electronic music... people don't know their harmony. Not all electronic music obviously, but it seems like that's always the first to go...
James |
Yes! One thing I forgot to mention is that I like the way that web page is set up, I was starting and stopping multiple pieces in unison with each other, and they chorused and harmonized very nicely. Playing that page was like playing an instrument! Well done. _________________ When the stream is deep
