Nord Electro 2: How to replace fuse?
Page 1 of 1 [22 Posts]
jojoman
PostPosted: Fri Aug 01, 2008 5:22 am    Post subject: Nord Electro 2: How to replace fuse? Reply with quote  Mark this post and the followings unread
Hello,
I just have a Nord Lead Electro 2 keyboard but the unit does not power on.
I opened it and i can't find a fuse.
Does someone have an idea?Wich part that needs to be replaced?
There is a black "thing" next to the voltage selector that say's "RN112-0,8/02 and also 0,8A/250V.
This has been soldered at the PCB.
Someone with more experience on this please?
PostPosted: Fri Aug 01, 2008 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Other Clavia synths have an externally accessible fuse, near the mains entry point.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Aug 01, 2008 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It's the black screw between the power knob and the serial number indication shield/sticker.
A small tube comes out and at the end the fuse is held in place.
Wout
jojoman
PostPosted: Fri Aug 01, 2008 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Wout,
I've been looking for a black screw but there is not screw. Crying or Very sad
The powerknob has the voltage selector behind it.There is no room between it to place a screw.
It does have a large blue capsule,but this has been soldered at the PCB.
Everything on the powesuply-board has been soldered.There is nothing that can be pulled off to replace it. Crying or Very sad
So strange.Most synthesizers have a fuse on the powerboard,wich is so easy to find and get it replaced.
But this Nord Electro 2 looks to be a pain in the ass.
PostPosted: Fri Aug 01, 2008 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It is on the outside, not inside the synth.
jojoman
PostPosted: Fri Aug 01, 2008 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
On the outside?
I've been turning this NE2 upside down for 20 times now and nothing noticable.
The only screws left to untight are those to disconnect the keyboard from the metal frame.
It is the Nord Electro 2 73 key modell.
Can someone provide a picture with what it looks like please?
Many thanks,
PostPosted: Fri Aug 01, 2008 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I found this pic on nordusa, is it different from yours? - follow the white arrow.
 Filesize:  31.12 KB
 Viewed:  12614 Time(s)
jojoman
PostPosted: Fri Aug 01, 2008 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Blue Hell,
Thanks for the picture but it's not like that.
It does not provide a fuse-port on the backside.
I do have a picture but i have no idea how to place it here.Can i copy it from my computer?I tryed but it's not working.
PostPosted: Fri Aug 01, 2008 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
You can attach it, when you post a message you'll see a button "add an attachment" somewhere below the area that you type in, click it and you'll get a new screen allowing you to pick a file from your local computer.
PostPosted: Fri Aug 01, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
No fuse ... weird ...
jojoman
PostPosted: Fri Aug 01, 2008 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
OK Thanks,
 Filesize:  56.85 KB
 Viewed:  312 Time(s)
PostPosted: Fri Aug 01, 2008 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It's the black tube on the right side of the PCB, normally it sticks out through the case so it looks like the image I posted Shocked anyway, on the side that sticks out it's a screw that you open up by using a screw driver with a somewhat largish blade, one quarter of a turn and it will pop out I think ... other wise a couple of turns.
PostPosted: Fri Aug 01, 2008 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Counter clock wise.
And welcome of course.
jojoman
PostPosted: Fri Aug 01, 2008 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
It's that black tube indeed.
But it's not complete,so that's way it did not recognized it Embarassed
It's missing the screw-part ,and i've been to a eletronics store a few minutes ago and they don't have that exact type mad, short circuit
So i'll have to search for a replacement for it.
Thanks for the help,
beer
PostPosted: Fri Aug 01, 2008 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Right ... good idea to replace it then Laughing well I'm glad it got sorted out, hope you'll be able to find something fitting for it.
jojoman
PostPosted: Fri Aug 01, 2008 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope so.
Thanks for the help again,
You guys rock.
thanks
wave
beer
cheers
PostPosted: Fri Aug 01, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
And I'm going to get me some Belgian beers for the beer bit. I deserved them I think, while you found the fuse I cleaned the windows, the ceilings, the walls, the kitchen, the toilet & what not Wink
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Aug 01, 2008 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe Clavia can help, only I think they are still closed for the moment.
Wonderfull picture of the power supply, special the flower print table decking. Surely, it must be Belgium, no mistake possible! I love the country for it! And the beer, of course Razz
BTW any chance our countries will come together again? The Dutch culture is, IMHO, mostly Flemmish and a bit Walonian!
Wout
PostPosted: Fri Aug 01, 2008 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
and a bit Walonian!
But only for the beer and the cheese .. not?
Clavia might be back next monday .. IIRC July was the holiday month for them.
jojoman
PostPosted: Fri Aug 01, 2008 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Who knows?
Holland and Flanders together as 1 country.
Not sure about that,should be much better for Flanders,those Walonians are only stealing are money we worked so hard for.
Maybe we meet sometime on a synthesizer meeting.
Help me to remember that i need to pay you guys some beers.
PostPosted: Fri Aug 01, 2008 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
May I request that you buy that beer for a poor Walloon "neighbor" instead; looking from outside it seems that Belgium is in need of such gestures Wink
In the Netherlands we have some of such stealing stories as well. Like the natural gas that's present in the northern part of the country which is supposed to be stolen by the people in the Western part. But then they forget about the social security network which was basically paid for by importing cheap labor from Spain, Turkey .. Poland nowadays .. into mostly the western part of the country where the industry happens to be mainly ...
I think that social interactions between different regions in the world are too complex to simply point to one region and say that they are stealing from another part ... and don't forget ... if any stealing is going on at all it usually is the poor being robbed by a couple of rich ones.
This is all just IMHO of course Rolling Eyes
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Aug 01, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan!
Come on, now...! Wink
You know very well the best Dutch beer is brew in the east and south regions of The Netherlands! What is made in the west is just non-purified water from the Amsterdam canals...
Stroopwafels is a different thing!
And you know why stroopwafels are from Holland, where all the other wafels are coming from Belgium? Simple because over here people find the later much to big and to tasty, with these warm cherries and whipped-cream. Stroopwafels are much cheaper Smile
Wout
