today> Cancelled - Sorry Chez Mosc
Anyone here tried the Doepfer A-199 Spring Reverb?
Page 1 of 1 [18 Posts]
Crazy_Jane
PostPosted: Fri Aug 08, 2008 3:26 pm    Post subject: Anyone here tried the Doepfer A-199 Spring Reverb? Reply with quote  Mark this post and the followings unread
I'm curious about how it sounds?
If it's a good spring sound, and if it's noisey or has hum problems in normal useage?
There's unfortunately no demos of it on doepfer's site, i love the sound of the vermona spring gear but if i can get similar cheaper that'll slot into my modular (or perhaps two of them for stereo) i think that's a better option.
Jari Jokinen
PostPosted: Sat Aug 09, 2008 6:18 am    Post subject: Re: Anyone here tried the Doepfer A-199 Spring Reverb? Reply with quote  Mark this post and the followings unread
I have both Vermona ReTubeVerb and A-199. The ReTubeVerb sounds much more natural and less springy than A-199. However, A-199 integrates to modular and is thus more flexible.
(A third option: Apparently it is possible use an external Accutronics spring tank with A-199)
Crazy_Jane
PostPosted: Sat Aug 09, 2008 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for that Jari! Very Happy
do you have a link to any tracks you've used it on? i'd be interested to hear the results Very Happy
dougcl
PostPosted: Sat Aug 09, 2008 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
A-199 recording here
http://www.analoguehaven.com/doepfer/springreverb/springreverb.mp3
Doug
Crazy_Jane
PostPosted: Sat Aug 09, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
ooooh thank you for that... doesn't sound bad at all.
is that with the spring in the a100 case? or have you mounted it in an external box?
dougcl
PostPosted: Sat Aug 09, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's not my clip. It's on the Analog Haven site. It's the tank that comes with the A-199. May or may not be inside the A100 case. I have two tanks in my case and I'm fine with it.
Doug
Jyoti
PostPosted: Sun Aug 10, 2008 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've just got an A100 system and I've done a little video of a patch wot I wrote:
Doepfer Drums from Jyoti Mishra on Vimeo.
It's got the A199 on the snare-type sound, should give you a bit of an idea what it sounds like. Cool
My music: here!
dougcl
PostPosted: Sun Aug 10, 2008 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well done. That sounds great, Looks like you are using the A-160 and A-161 in there. Still waiting on getting these modules in my setup!
Jyoti
PostPosted: Mon Aug 11, 2008 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, that's right. I'm going to get a step sequencer but in the meantime, those two are plenty of fun! Very Happy
I'm tempted to get another spring reverb so I can have a go at stereoness like Crazy_Jane said. I've got the panner and that's cool too.
Are there any other Eurorack spring modules available? Question
My music: here!
dougcl
PostPosted: Mon Aug 11, 2008 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got a pair of A-199's for this purpose and it's great. Here in the US AH is appears to be sold out of them. I got one used recently.
Ilanode
PostPosted: Wed Aug 20, 2008 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
There is (was?) one by Analogue Solutions which compares nicely to the Doepfer one. It lacks the feedback insert but every now and the it sounds nicer to me.
Jyoti
PostPosted: Wed Aug 20, 2008 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers, Ilanode! Very Happy
My music: here!
Crazy_Jane
PostPosted: Mon Sep 01, 2008 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
oooh thanks for sharing guys.
lol i ended up getting a lexicon MX300 as it does quite a good emulation and is a bit more versatile and better suited to my whole setup for the time being.
will still no doubt grab a a199 to try out at some point... but my GAS budget is depleted for now!
Jyoti
PostPosted: Tue Sep 02, 2008 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I currently have my Doepfer routed through an Alesis Nanoverb. Sounds good! Very Happy
My music: here!
astroschnautzer
PostPosted: Tue Oct 28, 2008 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
the a-199 is great, I have two tanks, the doepfer one and an acuutroncs tank, I use both and have made a switch that you can choose between eitherone easily, still have on empty place on the switch to add a third tank.
e-grad
PostPosted: Tue Oct 28, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers, Jyoti!
For those interested in changing the A199's reverb tank here's how it goes (quoting myself from another forum):
I've an Accutronics tank: 9 B B 3 D 1 B which just works great. I've demoed my combo to s.o. who immediatly got himself the same tank for his A199.
To my best knowledge you can pick any Accutronics tank with the following code: X B B Y D 1 Z wheras X, Y, Z can be choosen to your liking. See the Accutronics HP for their code:
http://www.accutronicsreverb.com/
The fixed parameters refer to output/input impendance and type of connectors.
Per
PostPosted: Fri Nov 21, 2008 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I think it is a better idea to get a real spring reverb than using the Doepfer. Nothing wrong with the electronics, but it is a bad spring.
On the other hand, using it with other spring tanks gives a low output. To my taste, it is too Lo Fi for most purposes.
P
e-grad
PostPosted: Tue Dec 02, 2008 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Possibly wrong input and output impendances? I've not experienced this prob nor the guy who uses another Accutronics tank with matched impendances.
