hi! i'm new!!
Page 1 of 1 [13 Posts]
lifeonmars
PostPosted: Thu Aug 21, 2008 3:50 am    Post subject: hi! i'm new!! Reply with quote  Mark this post and the followings unread
Hi i write from italia, sorry for my bad english: i would thanks all the guru of this forum for their patches, and...if you can help me...
i would try to reproduce this patch on my g2x, but i found problems, can you help me? the mp3 file is the sound i would, is from a korg ps3100.
Many many thanks to all!!
ps_solo.mp3
korg ps3100
 Filename:  ps_solo.mp3
 Filesize:  603.92 KB
 Downloaded:  903 Time(s)
PostPosted: Thu Aug 21, 2008 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome
lifeonmars
PostPosted: Fri Aug 22, 2008 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
HI!! Very Happy
Can you help me?
Laughing
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 22, 2008 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
erm.. Not the best at this kind of thing.. but it sounded kinda brassy to me so probably best to start with saw waves, though it is filtered quite a lot and probably tracking the keyboard. The way the envelope cuts the signal each time a new key is pressed, suggests note on is set up to restart the envelope and there seems to be a short delay between this and full volume, so your going to want to increase the attack time on the volume envelope... hmmm....well at least it's a start. Smile
iP (Ross)
PostPosted: Fri Aug 22, 2008 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
That's basically it I think and a bit of echo and reverb - I started trying it last night but got distracted Rolling Eyes I could not find good filter settings trying the multi-filter on 6 or 12 dB, I think the filter might have a separate envelope for modulation and there might be velocity sensitivity on that, but it could also be a slow rising attack phase.
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 22, 2008 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Both sound sensible to me.. Smile
iP (Ross)
lifeonmars
PostPosted: Fri Aug 22, 2008 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
IT'S A SAW WAVE from the ps3100 korg.
so the filter is a 12 db, the problem is:
the envelope!
Pleas read:
http://www.bluesynths.com/modules.php?name=Reviews&rop=showcontent&id=10
The best synth ever made! Laughing Laughing
Thanks again, a great huge from nord italy
lifeonmars
PostPosted: Fri Aug 22, 2008 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
EHHMMMMMMMM!
The best synth ever made.......
AFTER my g2x...
sure....
Very Happy Wink Laughing
maybe
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 22, 2008 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry,
I don't have access to that page, "members only" can you summarize what it says?
iP (Ross)
lifeonmars
PostPosted: Fri Aug 22, 2008 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
Wink
korg ps3100.doc
 Filename:  korg ps3100.doc
 Filesize:  545.5 KB
 Downloaded:  595 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 22, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm... had a quick read through that.. doesn't seem to be anything that special about the envelopes except the option to have a really slow attack. But i wouldn't say that was the case on your sample. I'd say just patch it nice and simple,
Saw OSC ->LP Filter -> ADSR - > Ouputs and tweak until it starts sounding close.
The .doc mentions that the envelope times can be modulated so that may be the effect used here, swap your standard ADSR for the modulateable one and set up a LFO to slightly modulate the attack time.. this may be the velocity like effect that Jan was referring to.
It also looks like there is only one ENV so I would imagine you will need to patch your envelope control output to modulate yr filter too. Smile
iP (Ross)
lifeonmars
PostPosted: Fri Aug 22, 2008 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
sure is what i do... but the sound is not the same..
so i need help
arrow
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 22, 2008 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not upload your patch (to this thread) and let someone have a look at it. Hopefully someone might have some ideas. I'm out of town for the weekend so can't really provide much input without my kit.
iP (Ross)
