CGS62 - Slope Detector
Page 1 of 1 [15 Posts]
funkyfarm
PostPosted: Sat Aug 23, 2008 6:03 pm    Post subject: CGS62 - Slope Detector Reply with quote  Mark this post and the followings unread
http://www.cgs.synth.net/modules/cgs62_sd.html
What a cool module, but I wonder if packing two units is optional ; running in parallel Quadrature /threePhase LFOs, or two AD envelope generators...
Such a small design !
Oh, yes, maybe i'd rather learn how to use my gate comp Smile
funkyfarm
PostPosted: Sat Aug 23, 2008 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup !
The Alison Project has two Cool
http://electro-music.com/forum/viewtopic.php?highlight=slope&t=26202
The Alison Project
PostPosted: Mon Aug 25, 2008 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love the Slope Detector's, I want two more.
 Filesize:  47.83 KB
 Viewed:  11181 Time(s)
The Alison Project
www.thealisonproject.com
neandrewthal
PostPosted: Mon Aug 25, 2008 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
What do you like to feed in? What do you like to trigger with it?
widdly
PostPosted: Tue Aug 26, 2008 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Steady!
I've been meaning to build one of these. I imagine it would be handy for combining envelopes into something more complicated.
The Alison Project
PostPosted: Tue Aug 26, 2008 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use it to trigger all sorts of things (eg's, clock's, vca's, gated lfo's etc)... I definitely don't have a standard usage for it.....
The signal I activate it with changes alot but one common way I use it is if I have a sequencer clock running from an lfo I will feed another wave from the same lfo it the cv standards....
The Alison Project
funkyfarm
PostPosted: Tue Aug 26, 2008 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you use both of them at the same time ? Smile
The Alison Project
PostPosted: Wed Aug 27, 2008 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
all the time, different sensitivity makes them switch at slightly different times
The Alison Project
funkyfarm
PostPosted: Fri Aug 29, 2008 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay !
I'm convinced.
i'll get three for my 3-Phase LFO. Smile
funkyfarm
PostPosted: Fri Aug 29, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ken Stone wrote:
The duration of this gate signal depends on the incoming CV and the setting of the sensitivity pot.
okay, can't omit the pot, so i'd only take a couple (space saving)...
But you omit the mysterious RANGE switch after the pot ?
CGS-62_SLOPE_15.PDF
 Filename:  CGS-62_SLOPE_15.PDF
 Filesize:  128.82 KB
 Downloaded:  422 Time(s)
synthmonger
PostPosted: Tue Sep 02, 2008 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
You misspelled Slope in your pdf.
Cat-A-Tonic
PostPosted: Wed Sep 03, 2008 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Sleazy Pope Detector
neandrewthal
PostPosted: Wed Sep 03, 2008 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, I never knew they made regular ones Razz
worldbank
PostPosted: Mon Jun 20, 2011 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
hey
i wonder if someone could help me with this..
i built it. all the parts are in right places. i put it on and connect a cable from lfo out or what ever to cv in, nothing happens, no lights.. then i put a cable from any of the outputs to adsr trig input, nothing. BUT, if i just touch the adsr trig input connector with the tip of the cable coming from the slope detector output(any) it seems to work.. according to the leds atleast.. what is wrong ? im 100% sure everything is wired exactly as in the wiring diagram.. ive checked it many many times..
thanks..
andrewF
PostPosted: Mon Jun 20, 2011 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
what transistors did you use?
sounds like a problem with them....or grounding (lack of)?
Good way to start troubleshooting is to check the emitters of each transistor (the ones with the arrow mark) are all getting +15V (or + 12V), also check the TL072 has +/-V on pins 4 & 8.
