How to sync 2 arps?
Page 1 of 1 [3 Posts]
fischek
PostPosted: Thu Sep 04, 2008 3:24 am    Post subject: How to sync 2 arps? Reply with quote  Mark this post and the followings unread
This has probably been asked before, but I wasn't able to find it anywhere. Anyway, how can I sync 2 arps running simultaneously so that they have the same BPM?
What I've done is I took one arp, then copied it to a different location so I could perform modifications on the sound but presumably with the same BPM. The problem is the arps aren't synced after I am done with modifying the sound.
Is there any other way?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Sep 04, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
There are two things: the BPM value and the starting of the Arp. The last one is done by the Shift functions. NL-b has to be synced to NL-a, or other synths.
Using [Shift+LFO1-Wave] sets the synth into a 'value mode' which are to be seen in the small screen. Set the values to the BPM desired as in the attached list.
Wout
The Extension 'htm' was deactivated by an board admin, therefore this Attachment is not displayed.
fischek
PostPosted: Fri Sep 05, 2008 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Wout!
