nord wave and midi??
Page 1 of 1 [8 Posts]
u_o
PostPosted: Thu Sep 04, 2008 1:46 pm    Post subject: nord wave and midi??
Subject description: how i work with midi?
can i work with midi and the synte?
i want to edit with midi you know..
or this is just record??
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Sep 04, 2008 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just short...
Musical Instrument Digital Interface is a way to communicate between synthesizers and computers. In one of the instruments there is a Midi Out connection to the second instrument connected by the Midi In. In sucg a configuration instrument two is played by the first one. This can be the computer, using a program which can send Note On and Note Off commands, Volume commands, Note duration commands, and so on. Such a program is mostly called 'sequencer'.
Wout
u_o
PostPosted: Thu Sep 04, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
you dont anderstend me i want its play like vst to edit my melodys
i cannot edit like midi with wav file
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Sep 04, 2008 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the syntax of your English writing is a little to vague to detect the question... No offence, BTW! Smile
What is it you want to edit...?
The sound of the synth or the notes in the song?
Wout
u_o
PostPosted: Thu Sep 04, 2008 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry about my english i lern it alone with the time...
i want to edit The sound of the synth like vst on midi chanel
then i do export you know..
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Sep 04, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Take your time to write a message. Using SpellCheck and a Hebrew-English dictionary will help for sure. Cool
i want to edit The sound of the synth like vst on midi chanel then i do export you know..
There is no Editor to the Wave published yet; the Clavia WaveEditor is a kind of librarian and can't be used to change the parameters.
Changing the parameters along with the son is done by recording the movements of the knobs in CuBase or a alike sequencer. To manipulate the synth soundwise use the knobs...
Wout
u_o
PostPosted: Fri Sep 05, 2008 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
one more question
how i am save the sounds i make?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Sep 05, 2008 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Manual Clavia Wave on Page 15 wrote:
Storing a Program
To store a Program without changing Program name or category:
Press the store button.
The Store button LED starts flashing, and the Program location is shown in the LCD window.
Press SLOT A or SLOT B buttons at any time to cancel the procedure.
Select a location.
Use the Program buttons or the LCD-dial to choose a Program location.
Press the store button to confirm.
The selected Program is overwritten.
Wout Smile
