Identifty multiples
Page 1 of 1 [4 Posts]
torsig1967
PostPosted: Mon Sep 01, 2008 1:39 pm    Post subject: Identifty multiples
Subject description: How do I make an economical modulo calculation?
I wonder if there's some really economical way to do modulo division?
I need that to be able to find multiples of certain values.
Example:
Let's say I have: y=12n (n=0, 1, 2, 3...)
And then I have a bunch of values (x1, x2, x3...)
I want logic HIGH when those x-values satisfies the equation above.
12, 24, 36 would give HIGH
13, 6, 41 would give LOW
And my guess is that the easiest way woud be to use modulo division and compare to 0. When result is zero then I have a multiple.
Hope this question is understandable.
Audio files: 297
PostPosted: Mon Sep 01, 2008 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
When you subtract the real value from the value ran through a note quantizer you'll get a zero result where the note quantizer outputs the same value as is on it's input.
By setting the the note quantizer to 12 (and the range to full, 64) and comparing the difference obtained to zero you should get what you sketched in your example.
But ... IIRC ... some extra trickery was involved for negative numbers ... the quantizer handles those different, and possibly there is a small rounding error ... like half a unit ... that needs to be compensated for ... it needs a bit of experimentation.
Maybe I have a patch somewhere ...
Audio files: 297
PostPosted: Mon Sep 01, 2008 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found : http://electro-music.com/forum/viewtopic.php?highlight=modulo&t=5302 - for the G2 though and it may have the errors I mentioned.
torsig1967
PostPosted: Wed Sep 10, 2008 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
But ... IIRC ... some extra trickery was involved for negative numbers...
That works just fine, also with negative numbers without any extra tryckery.
Thanks.
