today> Bill Fox solo tonight! Chez Mosc
Pianos on Nord Wave
Page 1 of 1 [11 Posts]
jamesb
PostPosted: Sun Jul 27, 2008 5:36 pm    Post subject: Pianos on Nord Wave Reply with quote  Mark this post and the followings unread
Hey.
I'm a keys player, mostly jazz and funk. I need to get a single 'do it all' keyboard. I think I'd get bored with the synthesis possibilities on the Nord Stage. The Wave would obviously be nice for sound creation, but has it got any nice playable piano/rhodes/wurlitzer/clavinet samples? I've got a 88 note controller that I'd use to play the samples from, just wondering if those sounds are even comparable to, say, the Electro samples?
Thanks! james
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Jul 28, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome jamesb
The best way to check this is going into a shop and listen. I don't know about the avaiilability of the wave in Singapore, so maybe you have to depend on the knowledge of users on this forum.
As I understand one can make his own samples on the wave, so it could be done...
Wout
radiospace
PostPosted: Mon Jul 28, 2008 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
The acoustic pianos that come inside the Wave are pretty bad. I'd say that's pretty much the worst sampleset inside the machine. It might have some uses as a building block for synthetic sounds (using Frequency modulation, etc.), but as a substitute for a piano it is a very poor one. There is only one velocity layer, so the gentlest tinkle and pounding with your fists is triggering the same sample.
On the other hand I've gotten some really great electric piano sounds from the Wave; ironically my favorite EP sounds I've made so far use not one of the electric piano multisamples, but the electric piano sound stored in the wavetable. The criteria here is not really how well it emulates a real electric piano, but just whether or not it is musical and pleasing, and these sounds are very much both. The Rhodes and Wurly samples are quite good to my ears, as well. (And, of course, don't have velocity layers.) Finally you can do some nice EP-like sounds using FM.
The Clavinet isn't very impressive.
There might be better Clav or piano samples available as downloads from the Clavia website. Or you can make your own. (Re-sampling another keyboard into the Wave is about as easy as cooking a frozen pizza.)
To some extent how good of an acoustic piano or clavinet sound you can get from the Wave depends on how much of its sample memory you are willing to devote to those two instruments; if you re-sampled, say, software like Ivory, and loaded it into the Wave with its full decay and sampling every note on the keyboard, that might take up a substantial proportion (most?) of the 180 MB of onboard memory, but it'd surely sound far better than the piano that ships inside the machine. (That piano -- a Yamaha C7 -- is only 1.6 MB!).
Even though the Wave isn't meant to be a traditional sampler per se, playing back realistic pianos and orchestral instruments, it does have some extremely nice samples in it: the strings, the mellotrons, and the accordians are all very good. I also like the marimba, vibraphone, and celesta samples.
You could surely put together a solid collection of sounds for everything except the acoustic piano... with that I think there is a very definite handicap in not having velocity layers; as listeners we have such familiarity with the instrument that we demand a much higher level of realism from it that can't be obtained very well without velocity layers.
jamesb
PostPosted: Mon Jul 28, 2008 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Wout - I'll definitely try to check one out. I think the dealer here in Singapore may have one.
Thanks very much for your comprehensive reply radiospace! You raise a good point about an instrument should sound musical - I guess most listeners won't care if the sound is a brilliant rhodes emulation or not! It sounds like nice keyboard sounds in the rhodes style can be obtained. I guess acoustic piano is not sooo important, because I use a technics p-30 which has a reasonable sound anyway.
I like the idea of mangling real samples to use them for a basis for totally new sounds. I've been playing with the ohm force symptohm melohman vst demo, and that's a great synth for doing this as well!
Thanks again for your help. There's not many sound demos of the wave around on the web it seems, so I'll try and get to play one asap.
Ivan
PostPosted: Fri Aug 01, 2008 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, but you can program dynamics by assigning both low-pass filter and program output knobs to velocity button. Doing so, you can get even softer sound when you play gentle, not only quieter. I think that velocity for piano samples on Wave is meant to be programmed, although I'd like to see velocity layering option in the future versions of Wave manager.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Aug 01, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Ivan
Wout
radiospace
PostPosted: Sun Aug 03, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, and that's exactly what they do with the piano patches that ship in the Wave. I don't think anyone would claim, either theoretically or especially after hearing the Waves' piano patches, that that is a completely successful substitute for having velocity-layering at the sample level.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 04, 2008 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
radiospace wrote:
... I don't think anyone would claim, either theoretically or especially after hearing the Waves' piano patches, that that is a completely successful substitute for having velocity-layering at the sample level.
Be frank... Good velocity sounds for piano are very rare and the best I heard so far are in the Nord Stage. Is the Wave the instrument to emulate a piano?
Wout
Ivan
PostPosted: Mon Aug 04, 2008 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course it cannot be substitute, but it is still better than no velocity response at all. I also have Nord Stage 88, but still prefer to play real piano, because "velocity layers" are unlimited...
Monk
PostPosted: Tue Oct 21, 2008 1:13 pm    Post subject: Hey Jazz man!
Subject description: Watch the Wave poly
Hi Jamesb, Just a watch out for you may be to check out the maximum poliphony (18 notes). I know you Jazz guts like your 11th and 13th chords in the left hand and wizzing about with your right hand....add a little sustain pedal and layer your sounds with piano and strings or rhodes and piano and you are gona get into trouble with hearing note piching if you aren't careful with your arrangements. It might not be a problem but its worth testing out before parting with any cash.
Ian
jamesb
PostPosted: Tue Oct 21, 2008 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian
I just picked up a nord electro pretty cheap, which I'm pretty happy with. And a secondhand nord lead 2 is on the way too! I guess it was a bit wishful thinking that the wave would be able to do it all
Thanks for all the advice Smile
james
