Pots for Sale
Page 1 of 1 [4 Posts]
bubblechamber
PostPosted: Mon Oct 27, 2008 12:10 pm    Post subject: Pots for Sale Reply with quote  Mark this post and the followings unread
I have a lot( about 500) more 50KB(linear) pots than I really need at the moment. I had to order 1000 or nothing...
They are Alpha style 16MM pots, vertical PCB mount.
$.50 USD each
100 @ $40USD
shipping based on weight, but i'll keep it cheap.
these are brand new and come with mounting hardware(nuts and washers).
 Filesize:  2.28 KB
 Viewed:  5642 Time(s)
 Filesize:  15.44 KB
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
macumbista
PostPosted: Tue Oct 28, 2008 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Which kind of shaft is it? One pic shows D shaft, and one pic shows knurled shaft... and what is measurement of the shaft? 6mm? Somehow that's not on the drawing.
macumbista.net
synthmonger
PostPosted: Mon Dec 22, 2008 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
If they're the knurled shaft kind I'd be down for 200.
macumbista
PostPosted: Mon Dec 22, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got a whole bunch of them, and they are smooth shaft (not even D shaft) actually. But maybe he has others....and I can recommend him as a reliable seller!
macumbista.net
