Buchla 200 " barberpole" Phaser?
Page 1 of 1 [16 Posts]
ericcoleridge
PostPosted: Tue Nov 11, 2008 5:36 pm    Post subject: Buchla 200 " barberpole" Phaser?
Subject description: Anyone know or make a guess? Link to video
I have long been intrigued with many of the design choices made on the Buchla synth systems, and was just watching this video:
http://www.youtube.com/watch?v=EUJdOu4z3h4
Around 3:06, the Phase Shifter display is enabled and you can see it visualizing the back and forth LFO control over phase shift. Out of curiousity, I was wondering if some if the august synth DIYers here, or anyone, had an idea of what kind of component is used for this display?
Its a really fantastic module, and I'd recommend watching this video in general to anyone interested in the Buchla modular.
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Nov 12, 2008 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the link Exclamation that display looks mighty cool Wink
widdly
PostPosted: Wed Nov 12, 2008 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
daves barbers shoppe...you're next...out to lunch..WTF?
Wouldn't surprise me if it has a motor in there.
Pehr
PostPosted: Wed Nov 12, 2008 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I just love that text Rolling Eyes Laughing
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
23isgood
PostPosted: Wed Nov 12, 2008 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took a vid of a 200e recently that shows the Barber Pole module. Check it out here,
http://www.vimeo.com/2084474
pete
Check out my music
Peake
PostPosted: Wed Nov 12, 2008 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave is David Kean, who commissioned the barberpole phaser and oscillator, and likely the resulting 200e series...
ericcoleridge
PostPosted: Thu Nov 13, 2008 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just to guess at the question I posed, maybe it's just an LED matrix, but mounted diagonally. So that when lines of lit LEDs 'rise', it appears as a diagonal motion.
It's freakin cool whatever it is.
StephenGiles
PostPosted: Fri Nov 14, 2008 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Never mind the LED matrix - who has the schematic of the barberpole?? Sad
etaoin
PostPosted: Fri Nov 14, 2008 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
That is exactly what it looks like in the picture above anyway.
http://www.casia.org/modular/
ericcoleridge
PostPosted: Sat Dec 06, 2008 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Read this on the SDIY Mailing List Archive; interesting:
> "Motorized" phase shifter? Could you explain this term? I mean,
> is there a device that produces "barber pole" phasing that actually
> USES some little motor, chugging away? If so, do you have any more
> details?
>Sorry, I was being cute. By "motorized" I simply meant that instead
>of a control voltage controlling the amount phase shift, that a
>control voltage would control the rate of change of phase shift, and
>that the phase shift could increase continuously, as if there were a
>motor in between. (Except for the fact that there's no actual motor,
>I think the term is very descriptive.)
>A barber pole phase shifter is where you have two or three parallel
>phase shift stages, a multi-phase LFO controlling them and an
>electronic fader fading between them all to make a phase shifter that
>would appear to go up (or down) forever. The notches travel up in
>pitch, and as they get higher they fade out and new notches fade in at
>low pitches.
>I don't know if anybody has actually built one of these beasts. I've
>always wanted to, it's been one of my dream projects for a while, but
>I've never had the time.
Harold Bode made one. I have no further details; I read a little blurb
about it in some tall, thin and expensive paperback at the Stanford
Bookstore. I wish I had bought that book now, just for that scrap of
information. I can't find much on the Internet about Harold Bode. I need
to go to the UW Engineering Library, and do a search on him.
As far as a barber pole phase shifter, the only way I have heard of is to
have a Shepard tone generator (a tricky circuit, that) controlling 8 phase
shifters and 8 VCA's. The Shepard tone generator creates 8 triangle
functions that are 45 degrees out of phase with each other (well, you know,
0, 45, 90, 135, 180, and so on). It seems like a pretty complex circuit. I
was thinking about building a circuit someday (in the future) where there
are 8 4-stage phase shifters; each 4-stage section could conceivably be
built from a single LM3900. It would be nice to have the capability of
using the 8 phasers, not only in a Shepard generator, but also in a version
of the Electronotes Waveform Animator that uses 8 different LFO's with 8
phase shifters to create a very rich chorused waveform.
However, the idea of a "motorized phase shifter" got me thinking...
What if you constructed an actual "motorized phase shifter," where the
amount and speed of the phase shifting is actually constructed by a motor?
It would be simple enough to do; a very simple implemenation would use 4
light-dependent resistors and the usual op-amp phase shift stages, where the
LDR's act as the variable resistors in the circuit. The 4 LDR's would be
placed around a rotating drum, which contains a light source (the LDR's,
drum and light source would be enclosed in something dark, of course). The
drum would have slits in it, which start off small, grow large, and shrink
down to nothing again, like this: <> As the drum revolves, the slits move
past the LDR's, letting in increasing then decreasing amounts of light on
the LDR's, which would result in a very gradual increase and decrease of the
resistance on the LDR's. This would create a phase shifting effect. I
think that a similar circuit may have been used to create vibrato in some
older organs. Think of it as a cross between a Univibe (the photocells) and
a Leslie (the rotating drum).
Now, what if you extended upon this "motorized phase shifter" so that there
were 8 independent phase shifters (of 4 LDR's each) that were powered off of
the same drum? And what if you created the drum in such a way as to stagger
the light that hits the LDR's of each phase shifter, so that the modulation
"voltages" of the phase shifters are essentially 45 degrees out of phase
with each other?
Take the above circuit, and add 8 VCA's, also based around photocells (much
like the Buchla Lowpass Gates). Have the VCA's controll the outputs of the
8 phasers, in such a way as to get a staggered Shepard tone effect. The
result is a Motorized Barberpole Phaser!
Of course, there are a few details to be worked out:
- What is the configuration of the cylinder? How are the slits staggered to
get the proper effect?
- What is the relationship of the phaser LDR's to the VCA LDR's?
- What sort of motor would drive such a monstrosity?
- How would the LDR's be arranged?
- How would you afford the 40 LDR's needed? Are that many LDR's needed to
get a good phase-shifting effect, or are less needed?
Still, I think it would be a very cool device indeed. Perhaps the cylinder
could be made out of clear plastic, with actual barber pole-type stripes
painted on to it (or better yet, a transparency could be made, with the
proper stripes pattern, and wrapped around the cylinder). Trying to figure
out how this device would work is taxing my exhausted brain, so I will stop
now.
Would this work? Would it be worth constructing? I think it would sure be
a cool device to own: some little chugging monstrosity that creates a
beautiful sound. You could slow down, stop, and reverse the motor, without
any of the strain that comes from trying to design a voltage-controlled
Shepard function generator with through-zero FM. Besides, it would look
great: some weird little mystery tube that is incorporated into your setup.
It would be great to have the tube visible, and surrounded by rings that
contain the LDR's, with the motor and belt driving the cylinder also out in
the open. (My vision of this also incorporates lots of brass and walnut, a
la scientific equipment of the late 1800's.)
Any and all advice on this idea is greatly appreciated. I am also
interested in any and all electro-mechanical sound modifiers that have ever
been used (the Hammond vibrato, the weird Morley/Fender electrostatic oil
drum echoes, Leslies, and so on).
Thanks,
Sean Costello
neandrewthal
PostPosted: Sun Dec 07, 2008 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like a drum buddy to me. Smile
jhaible
PostPosted: Mon Dec 08, 2008 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.pat2pdf.org/patents/pat04399326.pdf
What Bode describes is basically a combination of an all pass filter and a frequency shifter (running at very low modulation frequencies).
When you run a frequency shifter at, say, 0.1 Hz, you don't really get the impression of shift in pitch. But you get a continuous phase shift from 0 deg to 360 deg within 10 seconds. And as 360 deg is "the same" as 0 deg, it starts all over again. This phase shift chages with time, but is constant with frequency.
Now combine it with an ordinary all pass filter (Bode shows some creative ways to do that in his patent!), and you get a continuous "circular" phasing effect.
JH.
fluxmonkey
PostPosted: Mon Dec 08, 2008 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
or raymond scott's circle machine...
www.fluxmonkey.com
Funky40
G2 patch files: 5
PostPosted: Mon Dec 08, 2008 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
is it possible to patch it with your modules ? maybe with some insertionpoints ?
jhaible
PostPosted: Mon Dec 08, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Yes and no.
I have deliberately built my frequency shifter with a technology that allows very slow modulation, for that very reason.
And I have added a fixed all pass filter into my FS-1a PCB set for the same reason.
But I have not spent much time to optimize it for circular phasing applications. That is to say, much (probably all) you need is included in my FS-1a PCB set, but you need to experiment to really make it a good effect. Try different capacitor values in the fixed all pass filter section, for example.
And then I'm pretty sure that there are a lot of special features built into a dedicated Barberpole Phasing module like Buchla's which are not necessarily covered by the basic configuration of Frequency Shifter + All Pass Filter. Extra modulation paths, extra feedback paths. And just look at that knob that's wonderfully scaled in semitones per second!
ETA: From looking at the Buchla front panel, two things immediately show a difference:
1. Variable Phase Shift Center.
My guess: Maybe a voltage controlled all pass filter instead of a fixed all pass filter?
Something to try: Patch up a phaser, just the all pass filtered signal, without mixing the dry signal, where the all pass filter is in the Bode patent. Speaking of my modules, that could be a Tau Phaser in Vibrato mode, or a Krautrock Phaser with the "Modulation" (dry-wet mix) fully turned clockwise (fully wet). Or just use a phaser stompbox and disable the dry mix.
Instead of mixing in the dry signal, the up or down output of the frequency shifter is used. For good stereo effect, mix the phaser signal with up on the lefr channel, and with down on the right channel.
2. Stages
My guess (not hard to guess): That would be the number of poles/zeroes of this extra phaser. Tap the individual stages. (Not so good on my Tau, sadly. But good on almost any other phaser.)
These are just ideas. If you have a frequency shifter - mine, or any other that can run at fractions of Hz - and a phaser: Take these block diagrams from the Bode patent, experiment, and post your results!
JH.
Funky40
G2 patch files: 5
PostPosted: Tue Dec 09, 2008 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jürgen
