whomper
Posted: Mon Nov 24, 2008 11:10 pm Post subject:
Building a dual VCO module |
I am thinking about creating a dual VCO module and would like to use a single TUNE knob (dual gang) for both modules.
Is the dual gang reliable enough so that once I adjust the trimmers to be in tune I will be able to use a single pot to tune both modules?
I am reckoning to still require a FINE pot, not sure whether a 1K or 10K though. _________________ Erez Yaary
Buy my CDs at http://www.mellowjet.de |
neandrewthal
Posted: Tue Nov 25, 2008 12:14 am Post subject:
I don`t see why you need a dual gang pot. Why not just send the output of the pot to both PCBs? _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
whomper
Posted: Tue Nov 25, 2008 10:46 am Post subject:
I am under the impression that it would be advisable to separate the two circuits, and each pot to be connected to each circuit.
Can I safely connect a single non dual gang pot to the two boards? I am looking for all other pot-requiring features to be administered using a single pot. _________________ Erez Yaary
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Thu Nov 27, 2008 1:03 pm Post subject:
Hi Erez,
What you want to do is simply take the voltage from a Master Tune pot and run it to a CV input on each VCO, like Neandrewthal suggested. Because of the summing resistors (the 100k resistors on the CV inputs) the two VCOs will still be well isolated from each other. You can try something besides 100k for the summing resistor to change the range of the Master Tune pot (higher value will reduce the range). Running a single CV to several VCOs is very common - this is what is done with the keyboard CV, for example.
Tim (more Cro-Magnonesque) Servo |
neandrewthal
Posted: Wed Dec 10, 2008 9:06 pm Post subject:
neandrewthal wrote: | I don`t see why you need a dual gang pot. Why not just send the output of the pot to both PCBs? |
You, sir, clearly have no idea what you are talking about. Just today, I tried sending the output of the coarse tune on one of my MFOS VCO's to the CVSN of another one via a 100k and it made the pitch of the master VCO go up 2 octaves and hardly change at all when the knob is turned. What's up with that? _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
whomper
