The pipes are calling
Page 1 of 1 [5 Posts]
AngusHastie
PostPosted: Thu Oct 14, 2004 3:53 am    Post subject: The pipes are calling Reply with quote  Mark this post and the followings unread
Has anyone tried to build a patch that emulates bagpipes?
Cheers, Angus
Audio files: 297
PostPosted: Thu Oct 14, 2004 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Chet singer has something about reed woodwind instruments at http://members.localnet.com/~singer99/G2-Tutorial/Introduction.htm would that be any good ?
Jan.
AngusHastie
PostPosted: Fri Oct 15, 2004 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan.
I'll check it out.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Oct 15, 2004 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one might pass in a mix, the most difficult thing seems to be getting that sublime out-of-tune effect. Maybe someone with some experience with real bagpipes can tweak it.
It is just a pair of triple fm chains, the exp glide is used in combination with a pitch bend envelope for a little glitchiness and some more of the Pitch CV is mixed in to make it go sharp up top.
pipes.pch2
bag pipe lead
 Filename:  pipes.pch2
 Filesize:  2.22 KB
 Downloaded:  1706 Time(s)
AngusHastie
PostPosted: Fri Oct 15, 2004 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian
That's not bad when you play in a mid to high register.
I'll have a mess around with it.
