Electrical Specs for
Page 1 of 1 [3 Posts]
jksuperstar
G2 patch files: 18
PostPosted: Fri Oct 15, 2004 10:22 pm    Post subject: Electrical Specs for Reply with quote  Mark this post and the followings unread
I can't find any info on this topic anywhere: I'm looking for info about the Control Pedal input to the G2. The TRS input, not the "sustain" switch pedal.
What power does it supply?
How much current is available (what range of resistance or pot is good?)
Is it similar to other quality gear (Tip = input, Ring = power, Shield = GND) inputs, that can also accept a mono-type control pedal?
I've tried to look at this myself, and powered off the unit has +12V at the ring, and when powered down, there's 10K Ohms between RS and another 10K between TS, with 20K between TR. Does this sound valid?
I suppose this might be for Clavia, but I thought I'd ping the users to see if anyone has this info first.
What I'm looking to do is make some controllers that use this port (breath controller, theramin, pressure sensors, accelerometer, etc).
Audio files: 297
PostPosted: Sat Oct 16, 2004 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
On 2004-07-21 Rob Hordijk wrote the following on the NM mailing list :
Rob Hordijk wrote:
The extra global modwheel connections are only available on the G2X panelboard and regrettably not on the G2 panelboard. Making an extra connector as an override to the G2X global wheels to use other controllers shouldn't be difficult.
On the G2 there is not much to DIY, in fact there isn't anything worthwhile
(imho) to change to the G2, if at all possible.
But the G2 Pedal input is fine. It seems to be able to eat about any analog
signal. I run it fine with a Doepfer theremin module that outputs between -12V and +12V and it didn't blow up the pedal input. The useful range is 0 to 5 V, which is accidentally the 'practical' output range of the theremin module.
For virtually all controllers MIDI is fast enough when the 'controller to MIDI' box doesn't have to merge a lot of other MIDI data.
There is a lot of commercial stuff using MIDI. Personally I've been using
Peavey PC1600x controllers for a long time. The PC1600x has two extra analog input connectors and it can be programmed what these inputs do. Works fine. I still find the PC1600x a brilliant controller box.
/Rob
Jan.
jksuperstar
G2 patch files: 18
PostPosted: Sat Oct 16, 2004 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan...that helps alot (just knowing 0-5v is basically the limit)
I'll post my creations in the circuit bending/ DIY area in the near future.
