Best way to do "Thermal Contact" for tempco and IC
Page 1 of 1 [10 Posts]
mikeb
PostPosted: Sun Jan 28, 2007 6:53 pm    Post subject: Best way to do "Thermal Contact" for tempco and IC Reply with quote  Mark this post and the followings unread
I'm just wondering if anyone has any good advice for mounting the temperature compensating resistors to be in thermal contact with the IC's.
Should I be using thermal paste, and should I also be using some sort of glue (hot glue?) to keep things from moving around? It seems to me like getting them really well connected is going to be impossible anyways, since the round resistor won't be touching the flat IC much at all.
It all seems very inefficient and would require a lot of time to get the resistor at the same temperature as the internals of the matched transistors in the plastic IC. Which means that the oscillator is going to be drifting for a while when first powered up.. anyone have any tips/tricks to best do this?
PostPosted: Sun Jan 28, 2007 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I mount the resistor to come in contact with an IC then use a fillet of thermal compound between the resistor and the IC to get the lowest thermal resistance. This way the components will track each other in temperature fairly quickly. Your gear should stabilize within 10 minutes.
I would never use hot glue to attach the components ... Shocked
Bill
andrewF
PostPosted: Mon Jan 29, 2007 2:39 am    Post subject: Re: Best way to do "Thermal Contact" for tempco and IC Reply with quote  Mark this post and the followings unread
amen to that, guess thats why the big companies went digital.
the other analogue technique is a 'chip heater' circuit. EFM had such a VCO - but it took even longer to settle.
PostPosted: Mon Jan 29, 2007 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, phase accumulators used in modern digitally controlled oscillator (DCO) circuits certainly have enough bit "width" that the effect of a drifting crystal oscillators can be rendered negligible.
It would be interesting though to actually measure how much, and over what period of time, a modern analog voltage (current) controlled oscillator, with an exponential converter controlling it's frequency, actually drifts. I emphasize modern since newer components are so much more stable than older devices. Without data or evidence to support claims, can anyone really say its a problem unless they can prove it? Very Happy
Just some comments ... Thanks
Bill
Audio files: 297
PostPosted: Mon Jan 29, 2007 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean for a constant environment temperature ?
[Exp. converters usually rely on the exponential relation between a transistor's Vbe and Ic, which inherently has a temperature dependence. But maybe I misunderstood the "question"]
PostPosted: Mon Jan 29, 2007 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, one where the experiment could be conducted in a thermal chamber. I am lucky enough to have several computer controlled thermal chambers available to me to qualify designs. I know not everyone does. The experiment would be no good if the temperature were constant.
Exactly right, but thats what the TEMCO is for, to mitigate this dependence so that we get a nice "reliable" doubling of collector current for every 47 millivolts or so on the base-emitter junction. The question was in the lines of "Gee, how well does the temperature compensation work .. how fast ... etc...?"
Thanks Blue Hell ... Very Happy
Bill
Audio files: 297
PostPosted: Mon Jan 29, 2007 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, that makes more sense to me Very Happy
Yes ! would be an interesting experiment to try such for some configurations.
PostPosted: Mon Jan 29, 2007 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would be nice to see Blacet vs. PAIA vs. Waird vs. Your DIY vs. Moog Modular VCO ... etc .... who is the most stable of all and how do they compare in their tracking accuracy across several octaves? Too bad we have barely enough time in a day for more meaningful things right? Laughing
Thanks for your responses.
Bill
synthmonger
PostPosted: Thu Mar 05, 2009 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a schematic or website that explains how a heater transistor works? I'm looking around for a design that uses a single NPN or PNP as a heater. Still fishing around in google, no luck yet.
Sebo
PostPosted: Thu Mar 05, 2009 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
The Moog Prodigy and Rogue uses a heater, you can check the schematics
to see how it works, also the EFM Rogue VCO Clone have a little explanation
about how it works (if I recall right).
Sebo
My Music:
