What causes a transformer to buzz?
Page 1 of 1 [8 Posts]
LektroiD
PostPosted: Sat Jan 24, 2009 1:38 pm    Post subject: What causes a transformer to buzz? Reply with quote  Mark this post and the followings unread
I just bought an amplifier from ebay, and the transformer is buzzing, I asked around a few forums if this was normal, and apparently it shouldn't buzz at all. I have a feeling the guy will not take this amplifier back, as the return policy says "The seller will not accept returns for this item.", and although the description said "Perfect working order" I doubt I'll be able to take it back as I paid cash on collection, so I can't raise a paypal dispute.
Therefore I'd like to know what my chances are of repairing this are, for as little cost as possible. When I power up, the buzz is loud then stabilizes, if I can put it to text it would look something like this... 'TZZzzzzzzzzzzzzz'
I've checked the earth continuity from the tip of the cable down to the chassis, and it is fine, If anyone knows a remedy, please let me know.
Smile
Audio files: 297
PostPosted: Sat Jan 24, 2009 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Transformer buzz is not that odd, and it will depend upon the construction ... likely things moved in transport casing it to buzz now where it didn't before. This is not necessarily a sign that something is broken BTW, but still it could be. In some devices the magnetic field of the transformer can interact with the steel of the case. You'd have to take a look to see what is causing the problem in your case. When the transformer is mounted with rubber dampers you might need to replace those, for instance. Or when you see something that is obviously broken you'd have to fix that. Maybe you could post some pics here.
Please remove the power before you open the amp! And when you need to reapply power while the amp is opened please take care to not touch anything that could be connected to a high voltage, when it's a tube amp high voltage could be anywhere, when its a transistor amp its likely to be only the mains connected stuff to watch out for.
cbm
PostPosted: Sat Jan 24, 2009 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's a little demon in a transformer that sorts the magnetism, and if it's grumpy, it can also buzz.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
Audio files: 297
PostPosted: Sat Jan 24, 2009 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing true!
RF
Audio files: 28
PostPosted: Sun Jan 25, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the 'buzz' coming from the speakers - or is it actually coming from the transformer?
Loose windings in the transformer or de-lamination of the core could cause a buzz. You might be able to fix that by using some varnish on the windings.
If it's coming through the speakers it's probably bad power supply filter caps.
bruce
www.sdiy.org/rfeng
LektroiD
PostPosted: Wed Mar 04, 2009 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The transformer, hence the thread title - you can physically feel it vibrating Wink
The windings are not visible, there is an outer 'cage' welded to the transformer assembly, and the windings are wrapped in tape within this assembly. I will post a picture for clarification.
I was wondering if I could fill the whole assembly with rubber window sealant, or expanding foam (fire resistant, of course).
 Filesize:  105.89 KB
 Viewed:  154 Time(s)
LektroiD
LektroiD
PostPosted: Fri Mar 06, 2009 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I managed to trickle some varnish into what I could see of the windings with a paint brush. However, no change to the buzz, I can still feel it vibrating too. Any other suggestions?
I presume from what I suggested in my previous post was not advisable, since nobody replied.
LektroiD
PostPosted: Fri Mar 06, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, i was getting audible hum coming from my 160vA plastic encased Toroidal Xfrmr ( 2.2A per 18V winding , supplying 3 sets of rectifiers/ regulators/ smoothing caps.
Checking my current draw i was taking less than half the rating of the Xfrmr.
I had an 80vA toroidal left from the modulars previous incarnation and after reinstating i'm using almost 75% of it's rating.
Modular has 45 pcb's split between the 3 power boards.
Just out of interest i wondered what the potential was between Xfrmr 0V and mains earth ... 14.8v.
Does this affect the ground sleeve of the audio output jacks on the modular making with the ground sleeve of my yamaha mixer ??????.
As you add more modules to a big case, adequate and correct ground paths have to be considered, i'm still learning about this Laughing
hope you have luck,
from the borders
