Cloning the Serge Dual Universal Slope Generator (DSG)
Page 3 of 3 [62 Posts]
Goto page: Previous 1, 2, 3
toppobrillo
PostPosted: Fri Apr 11, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Emulator Archive also offer a EMU VC Lag PCB
I believe that I have the EMU lag pcb artwork in my flickr account
there exist 2 versions of this circuit- the EA clone is of the revision. no OTAs!
CJ Miller
PostPosted: Sat May 03, 2008 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all. I was just looking for my handfull of LM3900s... I know I have at least three of them here. I have never bought any but I should. Serge also used MC3401. I don't know how the LM2900 would do.
I have never seen or played with a Serge, but have always been fascinated with the versatile functions and processing. Can anyone tell me what the difference is between the positive/negative slews, and the DSG? All I have read is that the DSG is like those two together "with extra stuff".
andrewF
PostPosted: Sat May 03, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I think there isn't much difference between these chips, other than the 3401 has max VCC of 18V, the others can handle 32V.
Like you I have never actually seen a Serge, but as mentioned in this thread you can build the neg slew - it is an easy build and worth it. you don't have to use a 3086, 5 npn trannies will do.
otherunicorn
PostPosted: Tue May 27, 2008 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
LM2900 is a better speced version of the LM3900. There will be no problems using them instead of LM3900 or MC3401. I expect the only reason the latter were used is price.
If I recall correctly, A Positive slew works only on upwards going signals. A Negative slew works only on downward going signals. Their circuitry is quite different from each other. It's been a while since I played with mine because my VCO panel is still upside down on the bench Sad
http://www.cgs.synth.net/
CJ Miller
PostPosted: Tue May 27, 2008 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ken!
Yes, since then I've looked over some datasheets to see what the differences are. The MC3401 has a limited voltage range, and the LM2900 is the industrial spec 3900 with wider temperature range. I lucked out because at Unicorn Electronics (!) LM3900 are $0.59 each, but the LM2900 are $0.20 each! Cheapest Norton amps I've ever seen, so I stocked up.
I was looking at the boards for the slew circuits on your site, I was just noticing myself how different they are. I wonder if a few 3046 arrays might work where that field of NPNs is. It's a lack of discipline, I suppose, but I started feeling dizzy after about 40 minutes of tracing things on the positive slew. I am certainly not going to copy their layout on perfboard! If I meditate on it for a while I might see where things go.
I've heard that the DSG is like a negative and positive slope together - but different. Any ideas about how a DSG resembles/differs from combining a positive and negative slew circuit in the same module? These old Serge circuits are making me really curious! I'm going to put a small system together to try breadboarding these with.
GlassX
PostPosted: Thu May 29, 2008 9:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think these old modules have something to do with the Dual Slope Generator...
I believe that the DSG is simply an AD/AR Envelope Generator with the diodes/pots replaced with something like the four transistors on the Envylope.
However, there's a "signal input" that allows VC Lag. This input simply skips the logic gates/schmitt triggers, and is connected right before the Rise/Fall circuit.
By the way, I can get similar functionality (minus the VC rise/fall control - but I could use vactrols!) with my own envelope generator circuit.
CJ Miller
PostPosted: Sat May 31, 2008 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi GlassX. From what I have read, the DSG is more than a VC AD/AR. This sounds more like the Serge DTG to me. The DSG sounds like a much more general-purpose function generator. That doesn't have a VC slew added on, but that this is part of the same circuitry which also acts like EGs, LFOs, filters, envelope followers, etc, etc. But, this having been said, is based on my reading, not upon actual use or examination of an actual Serge DSG. It just sounds as if it is elegant and, to me, mind-bogglingly useful.
And yes, Envylope also looks like another very cool project.
GlassX
PostPosted: Sat May 31, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, the difference between the Dual Transient Generator and the Dual Slope Generator is the 1V/Oct and the direct Signal Input. And I can get all the functions you described with my circuit, even Filtering and Envelope Following. It's just a matter of feeding the Input into the integrator.
I just don't have voltage controlled 1/VOct rise/fall times, but that would be easy.
PrimateSynthesis
PostPosted: Fri Mar 06, 2009 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Coriolis wrote:
I guess you mean this one:
http://www.ori.org/~aaronc/synth/EnvyLope_V3.pdf
That link seems dead. Could you please post it here or know where else I could find it?
Also, you might want to check out the LM3900 application notes. It has a number of circuits that could be used in a synth.
Thanks Smile
Junk Rhythm
PostPosted: Fri Mar 06, 2009 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try here:
SDIY EnvyLope V3
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
Luka
PostPosted: Fri Mar 06, 2009 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
the envylope has some weird quirks, you can read about it in the pdf listed on the sdiy site. i would suggest the bergfotron version. they all the use the same jhaible core
problemchild
melbourne australia
PrimateSynthesis
PostPosted: Sat Mar 07, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
I had never even heard of Bergfrotron. I looked there and there seems to be a dead link to JH's design. Anyway, I found this:
http://m.bareille.free.fr/modular1/adsr/mb_cvadsr2.htm
Which seems to be based on the same cote. He also has PCB's for sale.
