Lorenzo
Joined: Nov 09, 2008 Posts: 375 Location: Trieste - Italy
Posted: Mon Mar 16, 2009 2:06 am Post subject:
MP3 encoding problem!!! |
I have to convert some files from wav to mp3...
but the encoder put at the biginning and at the and of the track a
little "mute space" and cut in bad way the track!
I try with Soundforge, Nero, Audiograbber... Switch
I try chaining 2 and 3 converts...
How I can resolve this problem?
Thank you! _________________ Yes!
Oh Yeah!
Wow! |
Joined: Apr 03, 2004 Posts: 24545 Location: The Netherlands, Enschede
Audio files: 299
Posted: Mon Mar 16, 2009 9:47 am Post subject:
mp3 works with blocks of data, so mp3 files can not have an arbitrary size .. maybe that is the problem? _________________ Jan
Lorenzo
Posted: Mon Mar 16, 2009 10:11 am Post subject:
| Blue Hell wrote: | | mp3 works with blocks of data, so mp3 files can not have an arbitrary size .. maybe that is the problem? |
so it is not possible add an text file like... m3u
so mp3 player read the file like differents files??
Oh Yeah!
Wow! |
Audio files: 299
Posted: Mon Mar 16, 2009 10:16 am Post subject:
I'm not sure what you try to do Lorenzo ... I'm guessing that you have several files that you want to convert to mp3 where the files should be played one after the other without any audible gaps, is that correct? _________________ Jan
Posted: Mon Mar 16, 2009 11:43 am Post subject:
Hmm... I've done tracks that fade into each other, and successfully converted them to mp3s (at least they sound ok in iTunes). I've used CDEx (PC) or Sox (Mac) - I think it was CDEx I used for those fades. Maybe worth a try, if you haven't already?
Lorenzo
Posted: Mon Mar 16, 2009 12:32 pm Post subject:
| Blue Hell wrote: | | I'm not sure what you try to do Lorenzo ... I'm guessing that you have several files that you want to convert to mp3 where the files should be played one after the other without any audible gaps, is that correct? |
Quite correct...
I had a long wav file (is my electronic live session).
I convert this in several mp3 files... but they plays with
ugly gaps between on track and another...
So I wonder if it is possible convert that wav file in a
single mp3 and add an text file (like .m3u or ... I don't know)
for make the player read this file without gaps
but virtually divided in traks.
(I have to put it online... )
sorry... my English is not so good...
Thank Antimon,
I will try CDEx... tomorrow... now I quite tired and frustrated  _________________ Yes!
Oh Yeah!
Wow! |
Audio files: 299
Posted: Mon Mar 16, 2009 1:25 pm Post subject:
This is a bit more involved than I had thought initially ...
The wikipedia article about gapless playback sums it all up ... http://en.wikipedia.org/wiki/Gapless_playback ... the problem is at both sides really, recording and playback ... and mp3 has no "official" support for gapless audio (although encoding with LAME and playback with winamp might work, some mp3 players also claim to be able to play back mp3s without gaps).
I don't think an m3u file can solve this ... as it's a playlist basically, telling the player in what order to play tracks, where to find those track and how long each track is. It would also need to specify a start offset into a track would it be able to make gapless audio, but there is no such feature. Pls files have the same limitations, look here for an overview of m3u and pls files.
In the wikipedia article it is suggested that the ogg file format would be better suited for gapless playback, this would still depend on the player to to do the right thing with the meta information in the file ... an also it says that all lossless formats (like FLAC) are inherently free of this problem.
Some discussions about mp3 splitting that seemed interesting :
http://www.hydrogenaudio.org/forums/lofiversion/forums.html/t62757.html
http://www.hydrogenaudio.org/forums/forums.html?showtopic=35654
http://www.hydrogenaudio.org/forums/forums.html?showtopic=35612&st=0&p=314141&#entry314141
Hairy stuff ....
And here is a link to the pcutmp3 program that is discussed in the links above : http://code.google.com/p/pcutmp3/ _________________ Jan
Lorenzo
Posted: Tue Mar 17, 2009 10:06 am Post subject:
Blue Hell, thank you very much for your kindness!!!!
I tried pcutmp3... but finally I'm thinking to use and upload in ogg format!
Thanks _________________ Yes!
Oh Yeah!
Wow! |
Audio files: 299
Posted: Tue Mar 17, 2009 2:58 pm Post subject:
Yeah, this pcut thingie seems not the easiest program to deal with ... maybe someone wrote a graphical front end for it?
I had been experimenting with gapless mp3s a bit as well, but many years ago ... and I gave up on it at that time ... so it's an interesting problem  _________________ Jan
Lorenzo
Posted: Wed Mar 18, 2009 12:18 am Post subject:
| Blue Hell wrote: |
... so it's an interesting problem  |
Using Foobar as player I notice that there are no problems with ogg file.
Even if looking the waveform with Soundforge there is gap in the beginning
of tracks still... in fact Windows Media Player can't read these continually.
I think it is strange that doesn't exist a file like .cue to add at an mp3 file
making the payer virtually read this file like several files.
It would maybe bypass gaps problem. _________________ Yes!
Oh Yeah!
Wow! |
Audio files: 299
Posted: Wed Mar 18, 2009 9:17 am Post subject:
The idea with ogg files, as I understood it, is that the true start and end points of the audio can be determined from the ogg file itself- so there would be no cue file needed. Of course the player will then have to use that information to do the right thing (as FooBar apparently does). For mp3 there is no "official" way to do the same, although some programs do use an unofficial way. _________________ Jan
