<on air> Twyndyllyngs Chez Mosc
touching on topic
Page 1 of 1 [3 Posts]
mysticalis
PostPosted: Tue May 26, 2009 5:51 am    Post subject: touching on topic
Subject description: just some thoughts
I believe daw's are as good or promotive as the user that uses it is.
Theres alot of knowledge that need to be grasped before daws can be fully utilized.
I don't believe it puts the user farther away from the actual composing.
It opens op for alot of fast productions that can be altered 1000s + ways using only mixer capabilites.
One can record using pc-keyboard, i actually do scales using that. One problem is the pressure that cant be read as on a midi keyboard. There are ways of compensating that.
But in the end is it good for the actual creativity?, yes if used to explore not to automate the whole creation.
BobTheDog
Audio files: 32
PostPosted: Tue May 26, 2009 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't fully understand your post but welcome to the forum.
DrJustice
PostPosted: Tue May 26, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi mysticalis!
You may want to check out this topic: A discussion of the DAW as a compositional tool.
DJ
