today> Twyndyllyngs Chez Mosc
Note sequencer rec and trig inputs
Page 1 of 1 [4 Posts]
AngusHastie
PostPosted: Wed Nov 24, 2004 4:48 pm    Post subject: Note sequencer rec and trig inputs Reply with quote  Mark this post and the followings unread
Hello all.
I'm trying to record note sequences in the SeqNote module by patching the Keyboard note output to the Rec input and the Keyboard gate output to the trig input (which I presume is the yellow one to the right of the Rec input), per the instructions on page 183 of the manual. However, doesn't really seem to do much! Like nothing. At all.
Any suggestions? I've searched the forum and can't find anything.
Cheers, Angus
AngusHastie
PostPosted: Mon Nov 29, 2004 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's an example of what I mean.
In this simplest of patches, why doesn't the sequencer advance by a step with each key press like it says it should in the manual?????
SeqNote rec and trig.pch2
 Filename:  SeqNote rec and trig.pch2
 Filesize:  1.03 KB
 Downloaded:  1629 Time(s)
PostPosted: Mon Nov 29, 2004 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
You need a clock. Try this:
SeqNote rec and.pch2
Sequence Record Example
 Filename:  SeqNote rec and.pch2
 Filesize:  1.03 KB
 Downloaded:  2099 Time(s)
AngusHastie
PostPosted: Mon Nov 29, 2004 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
