lasix
Posted: Fri Aug 14, 2009 10:08 am Post subject:
Micromodular not working after upgrade to 3.03 |
Hello,
I have a tendency to be verbose, so I'll try to keep it short.
Micro came in mail today
Listened to a few of the patches it came with ver2.1, then decided
to upgrade to 3.03.
Attached the device to midi in / midi out of novation sl mkii
and the patch started to go through until it got to 99% then gave
a message of er in the display.
Tried again with the slow (safer) checked and it completed the install to 3.03, it even said "Have fun"...
Well, when I unplugged then replugged it in, I could no longer scroll through the patches. Which isn't a problem as I didn't need to save the default patches, I plan on installing and making others. But it doesn't seem normal that I can't even get the patch number to go up or down at all. It's stuck at 1.
I'm hoping that if I am able to save patches all will be good with the world, but the editor won't discover the midi ports. It will say looking, then still looking/listening whatever. I've tried connecting with every interface I own, about 5 different sorts,... I turned on win 98 compatible mode, have the background as priority and have no other midi connected when I try to get this all working.
I would like to try and reinstall an earlier OS such as 2.1 or 3.0 along with the original patches, in order to get back where I started, but I can't find any older OS downloads nor do I have an idea about how it might be done. The OS updater doesn't give one very many options.
Any help would be greatly appreciated.
I intend to try and update it again on a different computer, if that doesn't work, I'm going to have a hissy fit. Then I will check back here for ideas.
Thanks |
lasix
Posted: Fri Aug 14, 2009 10:40 am Post subject:
So, yeah. My little Acer netbook just made my day...
I'm able to get the MM to see the editor and I'm pretty sure I'll be able to load patches now.
*sigh of relief* |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Aug 14, 2009 12:19 pm Post subject:
Anyway, lasix
Wout |
Oli
Joined: May 21, 2008 Posts: 250 Location: i think before i ambient
Posted: Sun Aug 16, 2009 9:06 am Post subject:
Wout Blommers wrote: |  |
Ditto. BTW, did you figure out what the issue was? I will be receiving a NM1 soon, and may have to update it as well.
Oli _________________ Good good study, day day up! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Aug 16, 2009 10:03 am Post subject:
Oli wrote: | Wout Blommers wrote: |  |
Ditto. BTW, did you figure out what the issue was? I will be receiving a NM1 soon, and may have to update it as well.i | Different platforms?
Midi through loop?
Wout |
jksuperstar
G2 patch files: 18
Posted: Mon Aug 17, 2009 7:46 am Post subject:
I'm guessing the upgrade blew away the saved patches, and if there where no patches as part of the upgrade, the Nord synthesizers don't just increment 1, 2, 3, 4 if there's no patches saved at those locations. The synth saves you the time of scrolling through blank patches
Load up some patches, and all should be well again! |
Oli
Posted: Tue Aug 18, 2009 12:13 am Post subject:
Does the loss of patches explain the lack of discovery of the device/port? _________________ Good good study, day day up! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Aug 18, 2009 1:37 am Post subject:
I don't think so...
Wout |
