Lexicon MPX1 Modulation Questions.
Page 1 of 1 [11 Posts]
edjwise
PostPosted: Sun Sep 27, 2009 8:03 pm    Post subject: Lexicon MPX1 Modulation Questions. Reply with quote  Mark this post and the followings unread
I wanted to ask if anyone own a Lexicon MPX1 and can explain the modulation. I have looked through the pdf manual and I do not understand if the lfos and egs can be used on any effect. This one thing is holding me back from buying one.
PostPosted: Sun Sep 27, 2009 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The routing structure, for MIDI, LFOs, EGs, etc, is enormous. Almost any one of those mentioned can be routed to control a parameter of an effect. MIDI CC msgs can be scaled or inverted on their way to the parameter, IIRC.
edjwise
PostPosted: Sun Sep 27, 2009 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
so I can use the envelope generators for pitch shifting amount? LFOs to control delay time? All while morphing between EQ settings?
PostPosted: Sun Sep 27, 2009 9:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, if you look at Section 4 of the user guide/manual, it describes all the sources that are available, and how to connect them to a destination. The parameters available as destination for each effect are listed in Section 7, where each type of effect is described (the box below the drawing, usually starting with "Mix" is the parameter list).
There's also a software editor available from the Lexicon MPX-1 download page.
edjwise
PostPosted: Sun Sep 27, 2009 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Envelope controlled crossovers? LFO controlled overdrive? Sounds kinda like Reaktor in a box. I think that im sold, thanks for the help.
PostPosted: Mon Sep 28, 2009 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure. The MPX-1 has been around for quite a number of years, but is still around for a good reason. I think it's the best general purpose effects box on the market!
edjwise
PostPosted: Mon Sep 28, 2009 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
It is suppose to sound good too. I have read a lot of people say "pcm reverbs" so Im bidding up now.
PostPosted: Mon Sep 28, 2009 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
It does have the same "LexiChip" as the PCM reverbs, but I have heard it does not have the same identical algorithms. That said, it sounds damn good.
edjwise
PostPosted: Mon Sep 28, 2009 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I won the MPX1 today . . .should arrive soon. Thanks again for the good info.
PostPosted: Wed Oct 14, 2009 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
How'd the MPX-1 work out?
edjwise
PostPosted: Wed Oct 14, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
It arrived and I have used it for less than an hour. I am working on reorganizing my studio. . .so its a big mess right now while I have some cables and other stuff on order.
It is sitting in a rack unplugged and unloved Sad
