CGS66 heatsink Q.
Page 1 of 1 [15 Posts]
Bodega
PostPosted: Tue Sep 29, 2009 8:12 pm    Post subject: CGS66 heatsink Q. Reply with quote  Mark this post and the followings unread
Hi wonderful ElectroMusic people,
I'm having a bit of a mental block here regarding the LM337/LM317 and heatsink set for the CGS66 I'm making.
Here it says it should be a TOP-3 heatsink:
http://www.cgs.synth.net/modules/cgs66_psu.html
Problem is that I can't seem to find a matching LM337/317 amongst the bazillions on Mouser. Everything seems to be TO-[something else].
Maybe I'm misunderstanding this whole thing - this is the first time I've ordered both heatsinks AND LM337s - but shouldn't they be the same format?
Any help much appreciated!
Matthew
ps. if anyone has a suggestion for LEDs on Mouser... again, there's just so many to choose from, it's a bit bewildering!
Adam-V
PostPosted: Wed Sep 30, 2009 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think that's actually a typo on Kens page, it should be TO-3
Adam-V
zthee
PostPosted: Thu Oct 01, 2009 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there any recommended size for the heatsinks? Like 4°C/W or something?
The ones I'm using now are running bacon hot, which might not be so good in the long run...
Bodega
PostPosted: Thu Oct 01, 2009 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers for the reply, Adam-V. I ended up ordering myself some TO-220s based on a recommendation that they would do the trick the same as a TO-3.
In hindsight, I wonder if that will fit....
Adam-V
PostPosted: Thu Oct 01, 2009 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
From Ken's site:
"Another factor limiting the maximum current that can be drawn from the unit is the size of the heatsink. With 600ma being drawn, each regulator can easily be dissipating 6 watts, and will require a heatsink with a rating of 12°C/W or better to operate in an ambient of 25°C. As heat in an enclosed space may well be greater than this, I'd recommend going for the best heatsink of the correct profile you can get. Hobby shops in Australia have them available at 8.5°C/W (50 mm) and 11°C/W (40 mm), depending on the shop, though I have used 63 mm heatsinks I salvaged from old switch-mode power supplies. "
Adam-V
Adam-V
PostPosted: Thu Oct 01, 2009 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the regulators you used are in TO-3 packages (a large rounded diamond shape) then they won't work. If they are TO-220 packages (a small rectangle with 3 legs at the bottom and a metal tag at the top) then they will work.
The following show the differences between the two packages:
TO-3 Package
TO-220 Package
Adam-V
zthee
PostPosted: Fri Oct 02, 2009 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
From Ken's site:
Adam-V
Was so long ago I checked that page I forgot about it!
Bodega
PostPosted: Fri Oct 02, 2009 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
TO-3 Package
TO-220 Package
Adam-V
Thanks Adam - that does make things more clear! My order should - knock on wood - arrive today with the heat sinks and I can see for myself.
[snip]
Bodega
PostPosted: Sat Oct 03, 2009 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything fits! I did have to widen the holes a touch, but no biggie.
I had one more question for you wonderfully helpful people:
Can anyone point me in the direction of a simple how-to for mounting the regs to a heatsink?
I seem to remember that the two should be isolated electrically, if obviously not thermally, with a certain kind of screw.
And you also put some kind of paste in between the two, right? Is it that white stuff that looks suspiciously like toothpaste?
I've been googling it and searching this board for a good hour with no luck - I must be using the wrong search terms, cause it seems like this would be a common question.
Adam-V
PostPosted: Sat Oct 03, 2009 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, the heatsink should be electrically isolated from the device but thermally coupled to it.
This is achieved with either mica or silicon insulators, plastic bushes and heatsink compound.
Have a look at these:
Insulating kits:
http://www.jaycar.com.au/productView.asp?ID=HP1172&keywords=heatsink&form=KEYWORD
http://www.jaycar.com.au/productView.asp?ID=HP1176&keywords=heatsink&form=KEYWORD
Heatsink compound
http://www.jaycar.com.au/productView.asp?ID=NM2010&keywords=heatsink&form=KEYWORD
Adam-V
Bodega
PostPosted: Wed Oct 07, 2009 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one - thanks Adam-V!
Adam-V
PostPosted: Wed Oct 07, 2009 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome.
Adam-V
active
PostPosted: Tue Feb 08, 2011 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm bombarding the cgs forum right now!
so i don't know much about heatsinks and am a little confused by the whole process, hence me trying to DIY route, trying to learn in a hands on manner.
so first thing, just simply soldering a heatsink onto the CGS066 is not properly isolating it from the device, correct? there needs to be some sort of insulation between the bottom of the heatsink to the board, right? And they connect to the circuit purely through the leads.
and then ratings and c/w stuff also has my head in a bit of a swarm. i'm hoping to run this unit at +/-12V. So would something like this guy work, or am i totally lost?
http://www.mouser.com/ProductDetail/Ohmite/EV-T220-64E/?qs=sGAEpiMZZMttgyDkZ5WiunankxlM5/VpbGFCQNy7vzA%3d
thanks for all your help!
magman
PostPosted: Thu Feb 10, 2011 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
active,
You don't have to worry about insulating the heatsink from the board, in fact it the pads it is soldered to on the CGS66 PCB shouldn't be connected to anything else anyway (If they are, there is a PCB short that should be removed).
You should have an insulting washer though, between the LM3XX devices and the heatsink, similar the the items Adam-V posted links for above. You also need an insulating washer between the screw that fixes the LM3XX devices to the heatsink. Heatsink compound is also a good addition, spread on both sides of the insulating washer.
As regards the heatsink itself, I'm afraid the size of the heatsink depends.
It depends on the voltage of your transformer and the amount of power you want to use on the PSU.
In simple terms the °C/W rating of a heatsink means how many degrees C will the temperature of the heatsink rise above the ambient temperature for each Watt of power dissipated by the heatsink.
As an example, lets say you pick a heatsink with a 10°C/W rating and want to fully load the PSU to 600mA with the transformer of 15V AC. The effective DC voltage of the rectified transformer voltage is a little over 21V. You want to use 12V, so this means the Regulator IC has to "lose" 9V, which it will do virtually all of in heat. With a 600mA load, this would equate to 5.4W.
Now with a heatsink at 10°C/W rating, this means the temperature would raise by 5.4 x 10°C or 54°C above ambient or 74°C in an average room, or in other words uncomfortably hot.
If you are using an 18V AC transformer, the temperature goes up by another 4.5°C/W (another 27°C in this example, to 101°C Shocked). If you are using less power the temperature goes down. If the heatsink is in an enclosed space, without any ventilation, the temperature goes up.
As regards the heatsink you linked to at Mouser, the detail page on Mouser states this as a 10°C/W, whereas the data sheet states this is as at least 7.4°C/W. For most applications, this will be fine as long as you don't try to take the maximum power out of the PSU and you are using a 15V AC transformer.
I think I've got these figures right, but please shout out if I've made any obvious errors.
All the best
Magman
active
PostPosted: Thu Feb 10, 2011 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
@magman
thank you sooooo much! it makes a lot of sense. i still need to read a bit more to fully grasp it, but i thank you for all your help.
