Will this work?
neandrewthal
PostPosted: Thu Oct 08, 2009 3:55 pm    Post subject: Will this work?
Subject description: gate sequencer
If I take ODIS, but only run it to the buffers for the first channel, then run it through an inverter (stolen from the pulse divider module) then to the buffers for channel 2, then run the same clock into the master divider, out the /8 output, then into the disable input, and connect the cascade outputs together, can I have a 16 step sequence without the need of an extra sequencer engine Question All Ears
