Nord Modular NM1 > NL1 or NL2 simulator patch?
Page 1 of 1 [4 Posts]
frankyl
PostPosted: Wed Oct 21, 2009 7:28 am    Post subject: Nord Modular NM1 > NL1 or NL2 simulator patch? Reply with quote  Mark this post and the followings unread
Hi everyone,
i'm using a Modular NM1 (old Version, not G2) and NordLead 2 (also old version, not 2x).
i was wondering, if there's a patch available for the Modular who simulates the NL1 or NL2.
I want to recreate some of my best NL2 patches on the modular to see if they'll sound quite similar.
would be thankfull for any help.
cheers
frank
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome frankyl
Take a look at http://nm-archives.electro-music.com/010_NordModular/011_Patches/Nord_Lead_Emulation/
This conversion, once made by a stagaire working at Clavia, isn't the best one, but they sound the same, well, almost.
These are three of the four PCMCIA cards (the other one wasn't possible due to copy rights)
All these are NordLead(1) Patches, no Lead2. The RingModulator is only used to control the Amp, not multiplying the Oscillators.
Play a while with these.
BTW the Random Patches are mine...
You can read out the values of the NM by just pointing out the knob.
To read out the NL just use Nord Generator at http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/
Wout
frankyl
PostPosted: Wed Nov 04, 2009 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
@Wout
Thanks very much, that was exactly what i was looking for. tested a few of them but found out that it is very difficult to recreate the sounds.
i suppose i'd need a recreated nord modular NL1 init sound. do you know if that one is available too?
i guess it would be much easier to recreate NL1 patches from scratch by having an emulated NL1 init patch on the NM.
thanks for your answer in advance.
cheers
frank
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 04, 2009 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
frankyl wrote:
@Wout
Who? Me? Well, we are the only two in this thread, so hard to be mistaken Very Happy
... i suppose i'd need a recreated nord modular NL1 init sound. do you know if that one is available too?
There is: that SetUp01.pch in the same link.
If you are on PC you can read the values of the NordLead in NordGenerator http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/ by using the mouse. Set the same value in the NM Patch.
Beware LFO1 has to be changed into another wave form, no Arpeggiator in LFO2, RingMod is not available neither Distortion (It is a NordLead1 emulation, not 2!)
Just a moment...
I see this SetUp01.pch is a rework special to LFO1. So far the better!
Wout
