musical time
Page 1 of 1 [16 Posts]
bachus
PostPosted: Sat Oct 03, 2009 7:29 pm    Post subject: musical time Reply with quote  Mark this post and the followings unread
I have been trying to create a "computable" definition of musical time. In doing so I have found it necessary to recognize two distinct types of musical time, rhythmic and arhythmic. Rhythmic time is characterized by a context of temporal expectations provided by a meter. Rhythmic time is displayed/edited in standard notation. Every note event that occurs in rhythmic time is linked to its position in its meter's accent map. Attached is a screen shot of the display of the upper levels of the accent map of 5/4 meter subdivided 2 + 3.
At one extreme arhythmic music has a pulse but no subdivision/accenting of pulse groups. Here accent is either uniform or evolves with a sense of smooth continuity. At its other extreme arhythmic music has little of no accent/pulse at all.
The basic assumption/restriction on time is that all musical events are expressed as an offset from the start of some measure and the offset is given in Chronons which unit is defined as follows: The number of Chronons in a whole note is equal to the least common multiple of all the standard note lengths known to the system including tuplets and tuplets within tuplets.
At present I am using 417372849653760 Chronons to the whole note. Such a definition allows for extremely simple definitions and fast computation of many temporal operations on standard note lengths. However defining a range of tuplets within tuplets can easily exceed the 64 bit limit of the current generation of machines. Still any ordered system of note lengths whether time, percent of measure, etc., could be mapped to Chronons (with the necessary approximations) with out fear of temporal "grain".
By habit I think in terms of music with meter. What alternative divisions of time seem most desirable to others is of great interest to me as would be thoughts regarding meter.
 Filesize:  126.96 KB
 Viewed:  281 Time(s)
bachus
PostPosted: Sun Oct 04, 2009 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a partial map of 12/8 compound meter. The bar height represents the strenght of an accent. But a meter's accents define a pattern of expectations not actual note accent values -- eh?
 Filesize:  133.44 KB
 Viewed:  272 Time(s)
bachus
PostPosted: Sun Oct 04, 2009 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is the map of 8/8 as a meter parsed 2+3+3. Which, with 5/4, should make clear that a time signature is not sufficient to define a meter. Though for simple and compound time the grouping has default values and can be derived directly.
 Filesize:  129.08 KB
 Viewed:  265 Time(s)
nobody
PostPosted: Sun Oct 04, 2009 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
This looks interesting, but I have to admit I'm not sure I quite follow along.
1. Why find a computable definition of musical time? What is meant by a "computable definition"?
2. What is a chronon?
bachus
PostPosted: Sun Oct 04, 2009 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry. The chronon is defined as follows: the number of chronons in a whole note is the least common multiple of all note denominations known to the system--both mensural levels and tuplets. This definition allows most all note length computations to be done with simple integer operations and relatively little logic.
I probably should have said an "efficiently computable" definition. Using the definitions of meters and chronons it is possible to answer the following kinds of questions quickly and efficiently: What note(s) is(are) the remainder after subtracting a double dotted eighth from, say, a half note. What is the duration (note length(s)) from a given offset to the next beat. What is the duration from a given offset in a measure to the next closest metric subdivision whose accent is equal to or greater than that at the given offset? What is the shortest sequence of notes that will fill the duration between any two offsets in a measure, etc, etc,.
Because beam grouping reflects meter accent positioning even generating simple score requires asking a lot of questions about a given note's metric context--in other words doing computations with musical time.
BTW For simple and compound meters one could dispense with the visual map interface though I think it still has pedagogic value. For asymmetrical and special definitions a user interface is obviously required.
Acoustic Interloper
Audio files: 89
PostPosted: Wed Oct 07, 2009 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
bachus wrote:
... the number of chronons in a whole note is the least common multiple of all note denominations known to the system--both mensural levels and tuplets. This definition allows most all note length computations to be done with simple integer operations and relatively little logic.
I'm not sure why the whole note gets to wear the LCM pants, but I'm in agreement with least common multiple being important. I usually think in terms of supermeasures when thinking about polyrhythms lining up on certain accent markers, rather than whole notes, but I am guessing that one musician's whole note is another's supermeasure. Or, am I wrong?
I am just getting to the point where I will be able to feed my Scrabble-to-MIDI program something more than static accent patterns. Each MIDI channel can have its own accent pattern length, and its own time-per-accent, so polyrhythms are easy enough, have been for a while.
I have just added Steve Reich's 2 tapes and a thumb (as contrasted with two turntables and a microphone), by permitting two (or up to 16) MIDI channels running the same (or different) accent patterns at different BPM rates. You can compute the LCM and get a fairly long supermeasure. (You can run all 16 channels at different rates if you like.)
But the next thing I want plan to do, maybe over Christmas, is to enhance the accents so I can pass an accent pattern generator function rather than a static accent pattern at play time. If the generator generates a cyclic repetitive pattern, no matter how long, this is still equivalent to typing in a (possibly long) static accent pattern.
But what if I pass it an iterated function, the type of which is often associated with generating fractals? I get regular, possibly self-similar structures, but not necessarily cyclic structures. One can't compute the LCM because, to find out what even one of the channels is doing some time out in the future, one has to call the iterated function for that amount of time. These iterated functions can be cheap to compute, and one hopes that they can generate interesting (listenable) structure. But, if they do not generate strictly cyclic accent patterns, then I don't see how one can compute a LCM in general.
I'll know better after I try it and hear whether it is listenable.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
bachus
PostPosted: Thu Oct 08, 2009 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Acoustic Interloper wrote:
...but I am guessing that one musician's whole note is another's supermeasure.
No, in my system the LCM/whole-note is a fixed value of 417,372,849,653,760. The size is constrained by the 64 bit limit but I think it will serve most situations. However a wide range of tuplets within tuplets, as suggested by Octahedra, would need a substantially larger LCM and 128 bit integers Sad
Meter is treated as conceptually and functionally distinct from rhythm. A supper measure created by the synchronization of two polyrhythm down beats would be a rhythmic element which doesn't get infrastructure support beyond what any rhythmic element gets except a little help in notation.
The tool I'm working on is inherently non real time and will be as much about musical analysis as music creation.
Acoustic Interloper
Audio files: 89
PostPosted: Thu Oct 08, 2009 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Make sense.
I was thinking on the way to work today, I'd have a heck of a time performing this analysis on music created by a non-repeating structure generator for accent patterns, but of course finger picking is repetitive.
Thelonius Monk is one of my favorite listens when I want to shake up my understanding of rhythm, if not meter. He's got his own sense of beat. Cool
bachus
PostPosted: Thu Oct 08, 2009 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks Like a very nice piece of work to say the least.
Acoustic Interloper
Audio files: 89
PostPosted: Fri Oct 09, 2009 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I found out later that the pattern used as an example in the paper is the Brazilian Baion. I learned this fact when I was invited to sit in with a university world percussion ensemble after I finger picked it for the prof on banjo. My finger patterns locked right in with the ensemble's drums with essentially no practice. My guess is that I learned it from listening to Brazillian percussionist Airto Moreiro on some Miles Davis albums from the Seventies.
The subconscious can do wonderful things!
usw
PostPosted: Thu Nov 05, 2009 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
scratch what about rational numbers ? Question
bachus
PostPosted: Thu Nov 05, 2009 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I give up. What about them?
usw
PostPosted: Fri Nov 06, 2009 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Being both symbols and numbers, they allow you to perform arithmetic operations in a very compact/convenient form and save quantization errors for the final stage, when applying them to the discrete time-grid of your choice
stripped down whishes, healthy regrets and a diversity of fears
bachus
PostPosted: Fri Nov 06, 2009 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! From its definition the number of chronons in a whole note is the common denominator of all note lengths known to the system including, for example, double dotted 13th-tuplets. This allows you to perform arithmetic operations in a very compact/convenient form without quantization errors Wink
usw
PostPosted: Fri Nov 06, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
salut
Acoustic Interloper
Audio files: 89
PostPosted: Fri Nov 06, 2009 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, blessed temporal harmony among the posters.
I've added a "todo" to dig up some of my 80's vintage texts on temporal logic and see if anything jumps out. It may not contribute here, but it might prove catalytic for my own composing.
