How do I hook up a hardware compressor to an audio interface
Page 1 of 1 [4 Posts]
DrLoK
PostPosted: Fri Nov 06, 2009 8:02 pm    Post subject: How do I hook up a hardware compressor to an audio interface Reply with quote  Mark this post and the followings unread
Hi. Thanks in advance for any responses. I have a focusrite platinum compounder I would like to hook up to my motu 2408mk3 audio interface. Can someone tell me how I would go about this?
EdisonRex
Audio files: 172
PostPosted: Sat Nov 07, 2009 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you trying to compress the output or an input signal? There are a few ways you could hook it up and have it work.
I happen to have a 2408 mk3 as one of my 3 interfaces, so I could comment on this, knowing what you're trying to accomplish with it.
Garret: It's so retro.
DrLoK
PostPosted: Sat Nov 07, 2009 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want to use it as an external effect in Cubase. So, I guess I want to compress internal signals.
abstraktor
PostPosted: Sun Nov 08, 2009 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
you would send the cubase tracks you want to compress to analogue outputs on the motu, hook up these to the focusrite inputs, then route the outputs of the focusrite to analogue inputs on the motu, which you could then record on cubase on new tracks.
the track outs from cubase would probably be an auxiliary bus you set up in the DAW, or the main stereo bus if you want to "master".
Basically what youre doing is going out into the analogue domain to use the compounder, and then re-digitising to record its outputs.
