svinesunds
Posted: Sun Nov 22, 2009 1:12 am Post subject:
Nord Stage and SPLIT Subject description: How do I create a SPLIT using two sounds? |
Hello! I'm from Norway, and have had my Nord Stage Ex 88 for about 6 months. I have not tried out so much of all the possibilities yet, but I'm very satiesfied with what I hear!! But I have one problem. I can't manage to create a split with 2 different sounds - one for the upper keyboard and one for the lower. I have the manual - both in .pdf and "paper" - and I know that Clavia have written about the topic. Maybe it's my english knowledge - or more - the lack of it - but I think it's not a good explanation of how to do it. It's just like they're let some information out?!? I don't know. Maybe I'm just dumb. But can you, guys, try to help me out? With a really easy "user guide" on the topic - s-o- e-a-s-y- t-h-a-t- e-v-e-n- a- n-e-w- b-e-g-i-n-n-e-r- f-r-o-m- N-o-r-w-a-y- m-a-y- u-n-d-e-r-s-t-a-n-d- i-t- ? |
Runge
Posted: Sun Nov 22, 2009 8:05 am Post subject:
Nord stage split |
Ok forstår du dansk? her er hvad du gør.
Under program select knappen (den store runde sorte knap til højre for display) side to sorte knapper ( keyboard zones 2/3). tryk på 2. Du har nu 2 zoner. Upper og Lower. I hver lyd sektion ( orgel, Piano, Synth) sidder, under sektion volumen knap , en knap der hedder KB zone select. Tryk på Shift (midt på keyboard) og zone select samtidig og du valger hvor på keyboardet (Upper eller lower) den pågældende lyd sektion skal spille.
Op langs med keyboadet sidder en række lyddioder som indikere hvor dit split er. Tryk på shift og kb zones 2 samtidig og splitpunktet flytter sig.
Du kan også trykke på KB zones 3 og du har nu 2 spilts på keyboardet. |
