<on air> Twyndyllyngs Chez Mosc
G2 output noise
Page 1 of 1 [11 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 30, 2010 12:01 am    Post subject: G2 output noise Reply with quote  Mark this post and the followings unread
I recorded a few seconds of the crackling noise coming out of my G2's main output. I have read about noise when USB is connected to a computer but it does not seem to be my case. it does it with or without USB connected.
It's an intermittent noise.
any suggestion?
thanks in advance
G2 noise2.mp3
noise coming out from G2's output 2
 Filename:  G2 noise2.mp3
 Filesize:  305.53 KB
 Downloaded:  2067 Time(s)
Audio files: 316
PostPosted: Tue Mar 30, 2010 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
If its not a patch doing the noise it's no good I say, and nothing like USB noise I've been having.
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 30, 2010 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
no Jan, it's not a patch Crying or Very sad
varice
Audio files: 29
G2 patch files: 54
PostPosted: Tue Mar 30, 2010 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
From the clip, it sounds like the noise is coming out of only one output. Is that correct?
Do you also hear this noise from the headphone output?
I had a problem where I noticed that one output was intermittently dropping in volume. It turned out to be just a bad connection between the cable plug and the output jack. After I removed and plugged the cable a couple of times, the problem went away.
varice
pOisK
PostPosted: Tue Mar 30, 2010 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Seraph,
I've exactly the same problem here !
I've mailed the Clavia Support but they didn't help me at all, just told me to go my local repair man ...
I've tested everything I think:
The noise comes, disappears et comes back again, it's really annoying..
I'have checked all the cables, tried the G2 alone on the power supply, even with nothing connected, just the headphones I can hear the noise on the right ear.
A friend of mine checked and rebuild the welds on the power card. The noise is still there.
The noise can disappear for an instant when I touch the synth and press it (on the red parts).
I've uploaded the recorded noise so you can hear it:
http://soundcloud.com/synth33
I don't have time to bring my G2 to repair, I hope it won't cost a lot to repair it ....
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 01, 2010 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you also hear this noise from the headphone output?1
yes, that's correct, noise on one side only.
I'll try with headphones and report Exclamation
thanks Very Happy
pOisK
PostPosted: Thu Apr 01, 2010 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
As I said before, it's the same on the headphones out. the noise remains in the right ear.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Apr 02, 2010 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
same here Crying or Very sad
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Apr 04, 2010 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh no, that’s not so good. That means that the problem is not just localized to the G2 output jack… it might be just something as simple as a cold solder joint somewhere between the DAC and the headphone amp/audio output jack… or worse, a circuit component is failing… Sad
varice
pOisK
PostPosted: Mon May 03, 2010 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello !
Good news !! Cool
I took my G2 to get it repaired: apparently, it was just a bad contact between the motherboard and the dsp optional card.
the guy has just correctly put the card on the slots and the noise has gone Smile
And it cost me 0€ Laughing
Hope it will solve your problem too.
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon May 03, 2010 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, unfortunately. It was a defective DAC in my case Crying or Very sad
translation: 150 euro to get it fixed Rolling Eyes
