The Karplus Strong eChucK DIY Project
Page 14 of 24 [577 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14, 15, 16, ..., 22, 23, 24 Next
Inventor
Audio files: 267
PostPosted: Fri May 14, 2010 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
jeff-o wrote:
How about a kit with all the parts but not soldered together? That cuts out most of the labor for whoever would be building these, but you still get the benefits of buying parts in larger quantities.
Well, it turns out that nobody is interested in offering kits at this time. It's a lot of hassle, you have to package everything up and lots of it is resistors of different values, etc. If you really want a kit, ask yourself: would I kit this thing for very little profit? The answer is probably no. If it is yes, then you can be our kitter! (just joking of course). So the best alternatives we can choose are bare boards and now assembled boards.
Les
dugernaut
PostPosted: Sat May 15, 2010 7:07 am    Post subject: Chimeing in... Reply with quote  Mark this post and the followings unread
Les
Hi all,
Les & I have had a bunch of discussions about kitting parts. I just don't think the time spent counting parts to put in bags is going to be profitable for me. OK, yeah, I'm Capitalist. So shoot me! Smile
I'm planning a line of modules (panels, jacks, and all) for sale and Les' KS will likely be one of them. If anyone knows where I can get DOTCOM style panels made at reasonable cost, PLEASE let me know!
rosch
PostPosted: Sun May 16, 2010 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
i have a question regarding the zener diodes. in the bom they're called Zen-4V7
does it mean they're for 4,7V (just like in resistor names)?
like these:
http://www.banzaimusic.com/4-7V-Zener-Diode-0-5W.html
Inventor
Audio files: 267
PostPosted: Sun May 16, 2010 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
like these:
Yes rosch, those are the correct parts. The zeners perform a soft clamping which is responsible for the tube-amp like sounds that occur when the feedback potentiometer is set above the half-way position.
Les
rosch
PostPosted: Mon May 17, 2010 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks! i'll have everything in stock when these become available!
Inventor
Audio files: 267
PostPosted: Tue May 25, 2010 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool rosch.
Good news, we have 50 KS boards on the way! Doug made several changes to improve certain aspects of the design and Jeff sent out the board design that I PMed to him. We will have boards in a few weeks and I will begin mailing them out when I receive them from Jeff. We haven't worked out a price yet but it will be low because we had so many boards made.
Les
jmejia
PostPosted: Fri Jun 04, 2010 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow awesome! i'm a total latecomer to this thread - but it's looking good!
Inventor
Audio files: 267
PostPosted: Fri Jun 04, 2010 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, welcome to the thread. I heard from Jeff today. He has received the 50 boards and they look good. I will receive them in a mail sometime in the next week or so.
Les
jmejia
PostPosted: Mon Jun 07, 2010 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
just finished reading through the thread and getting myself up to speed on your project! pumped on it!
does your clocking VCO have enough range to get into slower delay times as well? (not for KS - but it seems like it should work well as a standard VC-delay as well - if your VCO has the range?)
Inventor
Audio files: 267
PostPosted: Tue Jun 08, 2010 2:01 am    Post subject: Reply with quote  Mark this post and the followings unread
You know, I'm just winging this one, but if i recall correctly, the VCO covers more than the full range of the BBD.
Les
jmejia
PostPosted: Tue Jun 08, 2010 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
sweet! i'm pumped!
jeff-o
PostPosted: Tue Jun 08, 2010 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey! My parts arrived from Digikey today (have I ever mentioned how amazed I am at how fast their shipping is?). If all goes well, I'll have at least one fully populated KS11 board ready to play with! Hmmm, I suppose I ought to gather up all the other stuff I need to drive it...
Hey Les, what's the fastest way to get sounds out of this board?
Inventor
Audio files: 267
PostPosted: Wed Jun 09, 2010 4:00 am    Post subject: Reply with quote  Mark this post and the followings unread
jeff-o, the fastest way to get sounds out of this board is to breadboard a sequencer and drive the inputs with it. You can, for example, use a 4060 binary counter and put a resistor in series with each of the outputs (100k Ohm), tie the resistors together and connect that to the VCO and VCF inputs. Then connect a 0.1uF cap to that same summing node and hook the other end to the stim input. This is the minimal one-chip boolean sequencer circuit that I used on one of Mathe's two boards.
Sounds like you'll be the first one with a KS11 working, so more power to ya Jeff! Good luck with the build and have fun.
Les
jeff-o
PostPosted: Wed Jun 09, 2010 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I'll see if I've got a 4060 kicking around somewhere.
If I want to trigger single "plucks" on the board (say, to simulate a guitar string being plucked) I assume I can just connect the VCO and VCF to a set analog voltage, and pulse the stim input?
Inventor
Audio files: 267
PostPosted: Wed Jun 09, 2010 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Jeff, use pulse widths of 1ms to 10 ms if you do that.
Les
jeff-o
PostPosted: Wed Jun 09, 2010 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I'll hook up a one-shot to generate a pulse. Is there a preferred number, or is 1 to 10 mS just an acceptable range? Does the length of the pulse affect anything?
Les
Inventor
Audio files: 267
PostPosted: Thu Jun 10, 2010 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Jeff, the pulse duration affects the sound. In my experiments I found that 1 to 3 ms makes the best sounds. By the way I got some BBD chips yesterday and tested the MN3208. It makes great bass sounds, in fact too deep of a bass at the slower VCO settings. So you should have a good bass guitar sound for your laser guitar project!
Les
jeff-o
PostPosted: Thu Jun 10, 2010 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I'll aim for a pulse duration in that range.
MN3208, eh? I've got 3204s and 3209s right now. I'll have to order up some 3207s and 3208s as well.
I haven't actually finished my KS11 build just yet; last night I was out acquiring a nice donor guitar for my next project. It's actually a 6-string electric, but it should work just fine. I'll still only be able to fit four "strings" on it though, due to space and playability reasons.
Les
Inventor
Audio files: 267
PostPosted: Mon Jun 14, 2010 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey folks, I've received the boards from Jeff and I'll be mailing them out to anyone who pays for them. I feel that it would be best to wait for Jeff and myself to build test boards first though. That way in the event that there is a cut trace or jumper wire or some other issue, we will be aware of it and can inform you accordingly.
So for now I will take advance orders by paypal for boards. Unlike the first run, we have about 46 boards left to mail out so some who wanted multiple boards should get them now. And good news: the price is cheaper! A lot cheaper actually: only $12 each plus $3 shipping to anywhere, so a total cost of $15 per board. They're cheaper because we had so many made, obviously.
Also, if you ordered a bare board (not a built one) from the first run, I will send you a free board from this second run. I'm doing that because there were silkscreen errors that made the build really difficult and all the confusion probably was a bit of a bummer for some. So just keep your first run board as a memento and expect a free board in the mail soon.
To order KS boards, please send $15 each via paypal to lester.hall@comcast.net
I will keep records of the purchases and mail out the boards in a few weeks or so. If you are sending paypal in non-US dollars, there is an exchange rate that applies so please add an extra dollar or so to cover that. Or maybe paypal lets you specify a received price, I don't know. I'm just saying that some folks send me less cash than intended due to the exchange fee, to please try to compensate for that somehow.
Also please note that the $3 shipping is the same for international and for US orders. I finally figured out the right way to send these things - in padded envelopes via the US post office's least expensive service. I also realize now that I can't be going to the post office every few days with another onsie twosie of circuit boards because of time, gas, ans hassle, so please allow a few weeks for delivery as I collect the orders and put them together into one or two large mailings.
Thanks in advance for your orders and for your support on this project, it's been plenty of fun so far!
Les
jeff-o
PostPosted: Tue Jun 15, 2010 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well everyone, I have great news! I finally hooked up a basic setup to test the KS11 board. And, as expected, it works!
I set up a 555 timer as a "one-shot" pulse generator, that produces a 3ms pulse each time a button is pressed. The output goes straight to a set of headphones. I tested it with both an mn3204 and mn3209, both work well (as a side note, very similar, too). I've got 3207 and 3208 chips coming to try out as well.
Ah, what a fun little circuit! Love it! I'm looking forward to putting it to work in my next project...
jeff-o
PostPosted: Tue Jun 15, 2010 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scratch that bit about the 3204 and 3209 being almost the same. They're not, I just had to adjust the feedback a bit. Learning curve and all that...
Inventor
Audio files: 267
PostPosted: Tue Jun 15, 2010 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jeff, that is excellent news! Now I feel good about sending out the boards sooner than later. You won't have to wait for me to order parts and build a board for test cause Jeff already did it! Yay \o/ !!!
Les
Sound
PostPosted: Tue Jun 15, 2010 11:48 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Ordered Very Happy
Inventor
Audio files: 267
PostPosted: Wed Jun 16, 2010 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Sound wrote:
Ordered Very Happy
So far five boards ordered in just the first day, all international. From:
Germany
Norway
Greece
You know who you are! electro-music is such an international community!
Les
jeff-o
PostPosted: Wed Jun 16, 2010 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Inventor wrote:
Sound wrote:
Ordered Very Happy
Germany
Norway
Greece
Les
And don't forget Canada! Wink
Hey Les, I see a few parts marked "supply dependent" or "choose a value" on the schematic. I used the default values, but how do I go about choosing the right parts in these situations? Got any guidelines (ie. increase for this effect) to help, or am I on my own?
Also, has anyone developed a quick reference to determine which BBD to use to get a certain (stable, noise-free) frequency range?
