today> Twyndyllyngs Chez Mosc
8-Step Sequencer with voltage controllable pattern (VCPS)
Page 6 of 14 [334 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 12, 13, 14 Next
donpachi
PostPosted: Tue Jun 08, 2010 12:00 am    Post subject: PCB arrived Reply with quote  Mark this post and the followings unread
I got my PCB yesterday. It looks awesome. Thanks, Matthias Cool
mattias
PostPosted: Tue Jun 08, 2010 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias,
I got my two boards today. As always very well packed .
Would you know whether we can get the ferrite beads from Reichelt? They have some ferrites but I can't identify them. Sad I know that Jürgen Haible uses ferrite beads from RS.
Also, is the Reichelt part no für RN1 and RN2 SIL 9-8 100K?
Thanks.
Red is black and plus is minus. http://www.bild-schall.com
PostPosted: Tue Jun 08, 2010 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
for the resistor entwork you want an 8 resistor 9 pin network in star configuration:
SIL 9-8 100k
i can't find beads at reichelt either. i use 10R resistors. it is saver anyways. the project has a lots of wiring, and a small mistake can cause a lot of troubles. a 10R resistor would hopefully protect the ICs in the worst case...
PostPosted: Wed Jun 09, 2010 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
magman wrote:
The BOM shows 16 SPDT toggle switches, when the design only shows 8. A small issue I know, but worth correcting.
thanks for taking care.
i updated the docs and added a page showing first option for wiring the PCB as simple 8-step without ADC. an 2nd option using even less parts will follow...
a100user
PostPosted: Thu Jun 10, 2010 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
PCB's arrived.
Thank you for the great service, as usual.
David
PostPosted: Thu Jun 10, 2010 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
i worked on the documentation a little bit more. it won't be the final version, though. Rolling Eyes
IMPORTANT CHANGES:
R6 is now 0k (jumper) instead of 100k.
some might want to power the module with 12V, so i gave a hint how to accomodate the ADC reference voltage (R26 at trimmer T1 shall be 200k then).
i added a 2nd option for wiring the PCB as simple 8-step seq without the ADC. saves even more parts. however, both options are not tested! i built two versions of this seq and i don't think i need another baby8.
and last but not least i explained the buffers/amplifiers that feed the CV potentiometers, and explained how to set them up (gain). you will find the new information on the BOM page.
now i am working on an explanation of the gray code (patterns) and a calibration procedure...
building documentation 10JUN2010.
sorry for the inconvenience, but writing up the docs took more time than i expected, so it is work in progress...
emdot_ambient
PostPosted: Thu Jun 10, 2010 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
SIL 9-8 100k
Just making sure...are these the same thing?
PostPosted: Thu Jun 10, 2010 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
bingo! the bussed ones.
beautyofdecay_
PostPosted: Fri Jun 11, 2010 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
Boards received today. Excellent quality.
Looking forward to building these.
adambee7
PostPosted: Fri Jun 11, 2010 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Arrived today, Cheers matthias. Very Happy Very Happy
delayed
PostPosted: Fri Jun 11, 2010 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
got my board in. USA TN
Thank you,
PostPosted: Fri Jun 11, 2010 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
great.
before building download the latest version of the buildong docs (it is still work in progress, as i said before).
emdot_ambient
PostPosted: Fri Jun 11, 2010 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived safe and sound today. Awesome.
tommi
PostPosted: Sat Jun 12, 2010 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Board arrived here too! Red one and in perfect shape! I like the PCB Very Happy
Reminds me of the x0xb0x's build...
Thanks Matthias!
And thanks for taking care of the 12Volt guys like me Wink
http://tideofsound.net
Audio files: 161
PostPosted: Sat Jun 12, 2010 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 Boards arrived safe in Scotland today , thanks very much Matthias.
Boards look fantastic , cheers.
rosch
PostPosted: Mon Jun 14, 2010 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
yep mine was here on saturday too!
looks great!
thank you!
PostPosted: Mon Jun 14, 2010 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
just a subtle reminder to all whom it may concern:
check your PMs inbox and/or email for payment info, boards are in...
KEYKEYEYEKIT
PostPosted: Tue Jun 15, 2010 10:50 am    Post subject: vcps8 boards Reply with quote  Mark this post and the followings unread
Got my boards today here in sunny Atlanta, thanks again!
scriptstyle
PostPosted: Tue Jun 15, 2010 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
hopefully when i get the time/money these boards will still be available. this is going to be a very chaotic summer for me...
modulus in moduli
PostPosted: Wed Jun 16, 2010 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Got the boards! I have to finish some other projects before starting this one. I also still have to decide whether to build it in two euro modules or a double stand alone...
Christophe
PostPosted: Wed Jun 16, 2010 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
i found the stand alone build to be much easier. it is not that cramped. all the wiring, you know...
diablojoy
PostPosted: Thu Jun 17, 2010 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
recieved boards in OZ today, all good , and they really do look great Very Happy
thank's mathias
tommi
PostPosted: Thu Jun 17, 2010 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,
I 've noticed that in the BOM, R8 have an asterisk wich concerns about the gain of the CV buffers. But as it's shown on schematics R8 is the timing resistor for the adc clock. Am I skeeping something?
Sorry if that's a silly question...
thanks! Very Happy
PostPosted: Thu Jun 17, 2010 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
not a silly question. silly me. the asterix are leftovers from previous doc revisions. i corrected the file right now...
BTW i hope i will finish the gray code and calibration desciption on monday.
thanks.
tommi
PostPosted: Tue Jun 22, 2010 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone have build it?
I finished my build yesterday but i 'm having problems. Sad
I am feeding it with +/-12V and i changed R36 to 200K. I 've also used 10K resistors on the feedback path of the CV buffers and used a jumper for R6.
I 've clocked it with an lfo's square wave and it's ok. But when i set the switches to the ADC position nothing happens... i 've only got step 8 hi and all others low, and nothing changes if i move the fine and coarse knobs or if i feed a signal to the adc input. The voltage status leds are working.
Gate and trigger out and associated leds are working.
I've connected the cv out to an oscillator and it seems that the cv pots have no effect on the output. The oscillator controlled by the cv out is flopping between two semitones like, say: step1: C, step2: C#, step3: C, step4:C#, etc etc..
I 've checked the +5V and it's where it's supposed to be.
Any hint?
Thanks,
tommi
