today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
Nord Lead 2x Sound Editor
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
Dynaudio82
PostPosted: Wed Jun 23, 2010 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout Blommers wrote:
temptation_07 wrote:
... About your question of the menu, you mean this?
Yes, that's what I mean Smile
Are those 'Yoke' ports special Midi ports? I would select [828mk2] in both menu's. If you check it again, they will probably have been changed. That's a bug in NordGen. Select at MidiIn the [828mk2].
Is the Midi In on the Motu connected with the Midi Out of the synth?
If so, perform [Shift+DumpOne] see if the parameters (knobs) in NordGen has changed...
I forgot to tell you to open [Sysex] and select in the menu [receive]!!!
Embarassed
Wout
(fingers crossed)
Yes the Midi in of Motu connected in Midi Out of synth... Sorry for the delay i get internet problem but im back...
Well about the Midi Yokes dont have any function for the moment because are not completly installed, in theory they creates internal MIDI devices for standalone Software Musical Instruments...
This is the site: http://midiox.com
and my unresolved problem of why i dont finish yet his configuration:
http://www.midiox.com/cgi/yabb/YaBB.pl?board=MOXInstall;action=display;num=1277332439
About the NordGen, i follow step by step your words but, not works yet Sad
exactly what i will see in the NordGen when this star working correctly? Rolling Eyes
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jun 24, 2010 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="temptation_07"]... Sorry for the delay i get internet problem but im back...[/quote0Well, I'm on the other side of the pond, so I went to bed Smile
... exactly what i will see in the NordGen when this star working correctly? Rolling Eyes
No flags nor horns Wink As soon as you send the synth command [Shift+DumpOne] the knobs in NordGen will change, if you selected [Sysex > receive]. When the drivers aren't installed mostly NodGen won't recognize the Midi ports. If you want to make sure download the drivers from the Archive page I send you before and copy&paste this in the Windows system folders.
Wout
Dynaudio82
PostPosted: Thu Jun 24, 2010 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe ok perfect Very Happy
Wout
what means DumpOne? where is it? Embarassed
about the Midi Yokes i will back here when i resolve it Confused
by the way... exist some manual in spanish of Nord Lead 2x?
and also Thank you very much for all the help than you give me and the time than you take Razz
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jun 24, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
... what means DumpOne? where is it?
The button next to the PitchStick. It's the OctaveUp button which function as 'DumpOne' when holding Shift too.
Wout
(BTW out of sync again, so off to bed Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Jun 24, 2010 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
If there is a Spanish version of the Manual, this address should know...
Hermes Music
Naranjo #76
Col. Sta. María la Ribera
D.F. c.p. 06400
Mexico
mailto: dcarranza@hermes-music.com.mx
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Jun 28, 2010 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
And when this isn't working either, try switching the Global Midi channel to channel 16.
Wout
Dynaudio82
PostPosted: Sat Jul 31, 2010 2:54 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Hello Wout i dissapears for long time hehe Very Happy No internet here and many music work... but im here again...
I want ask if you can put a photo with red circle of "DumpOne" here?, because im a bit confused and i dont really understand what you mean Embarassed
About the NordGen, i cant use it already, i will install soon Win 7 in my new computer so i will follow again your steps there...
Another thing than i want share with you are two Dashboards of Nord Lead 2x... maded in Synthmaker
The first one is for send and recieve Sysex, but in fact... I dont really know how i should use it....
The second one is for manipulate the Nord Lead 2x knobs like a VST, BUT the problem is than dont work correctly, this ones are the files and at the same time you can test how works with the nordlead if you have the Synthmaker.
Also with this files some ones than Know about programing in Synthmaker can make good modifications and then they can share after here with us Razz
Greetings and hope by your replys...
Nord_Sysex_thing.rar
Sysex
 Filename:  Nord_Sysex_thing.rar
 Filesize:  8.83 KB
 Downloaded:  375 Time(s)
SMG Clavia Nord Lead 2.rar
Nord Lead controller
 Filename:  SMG Clavia Nord Lead 2.rar
 Filesize:  103.3 KB
 Downloaded:  372 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Jul 31, 2010 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
... I want ask if you can put a photo with red circle of "DumpOne" here?, because im a bit confused and i dont really understand what you mean Embarassed ...
Push Shift together with the button labeled DumpOne.
The synth will send the SysEx of only the active Program.
Wout
 Filesize:  28.6 KB
 Viewed:  18153 Time(s)
Dynaudio82
PostPosted: Sat Jul 31, 2010 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahhhh the octaves! sorry i need new glasses hehe Embarassed
than you very much again Wout! i will tell you what happen soon, when i get my new computer...
greetings!
