"Son Of Storm Tide" Flanger
Page 7 of 14 [330 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 12, 13, 14 Next
interested?
yes
97%
 97%  [ 43 ]
no
2%
 2%  [ 1 ]
Total Votes : 44
numbertalk
PostPosted: Sat Jul 10, 2010 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH, a few more questions:
1) Is a 1W zener ok for the 10W diode, if it will fit the footprint on the board?
2) You mentioned something about temperature with the '5mm' caps in the BOM - for the really low values (33pf, etc) do you mean that one should/could use NP0/C0G? Or do you not mean stability with temperature but rather their ability to handle temperature and not meltdown so if possible use film here?
3) The 1uf non-polarized, this should be an electrolytic? I'm assuming so, since you say non-polarized, but just making sure elec is preferable to film here.
4) Is the difference in the bounce polarity drastic enough I might want a panel toggle for it? I ask because I always order my panels before I start a project, so won't be able to try it out first (could always leave it off and drill it later, but would just as soon include it when I design it).
5) Finally, just confirming, no need for on-board fuses when using AC power? Of course there will be an external fuse.
jhaible
PostPosted: Sat Jul 10, 2010 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should work
Don't worry. Just use what you can get.
Film is always preferable to electrolytic, if it fits into the pcb space.
I'd try what you like better, and then put a jumper to that position.
You need primary and secondary fuses.
On some of my PCBs, the secondary fuses are already there (because there was PCB space left). On PCBs where they are not included, you need them anyway (off-board).
Only if you're using a short-circuit-protected mains transformer (like many wall warts with AC output), you can omit the extra secondary fuse. (Because it's already part of your short-circuit-protected mains adapter)
JH.
numbertalk
PostPosted: Sat Jul 10, 2010 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
So what rating of fuse for the secondary ones?
jhaible
PostPosted: Sat Jul 10, 2010 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Such that it doesn't blow normally, but securely blows before your transformer starts to burn.
No general rule for that - refer to the transformer you're using.
JH.
numbertalk
PostPosted: Sat Jul 10, 2010 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
JH.
numbertalk
PostPosted: Sun Jul 11, 2010 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm finding that the B80C1500 is difficult to source in the U.S. - any possible replacements for this?
Also will any germanium diode do? I'm finding one with the description "work-alike for 1N34a and others".
Finally, those 100uf caps near the CD4007 are really only 6V?
Thanks.
jhaible
PostPosted: Sun Jul 11, 2010 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
B80C1500 just means the bridge rectifier can stand 80 Volts and 1500 MilliAmperes. Whatever fits that spec, and fits the PCB space, will fit.
1N34A will be fine.
Yes, 6V rating. Higher voltage is fine, of course, as long as it fits into the limited space.
Jh.
numbertalk
PostPosted: Sun Jul 11, 2010 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
This one should work, right?
https://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_178132_-1
Though this one's Maximum RMS Reverse Voltage is 70VDC - is this is the spec I want to be 80V, or the Peak Reverse Voltage, which is 100VDC. In that case I found this one:
http://www.mouser.com/Search/ProductDetail.aspx?R=W02Gvirtualkey62110000virtualkey621-W02G
jhaible
PostPosted: Sun Jul 11, 2010 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Both look good.
JH.
numbertalk
PostPosted: Sun Jul 11, 2010 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Both look good.
JH.
Great, thanks!
numbertalk
PostPosted: Sun Jul 11, 2010 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another parts question - the LFO selection toggle is a SPDT center-off, right? How is it wired exactly?
jhaible
PostPosted: Sun Jul 11, 2010 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, I already started typing an answer. In doubt, I always tend to think I've been sloppy in my online documentation, and forgot about the switch wiring.
But in fact, I have not been sloppy: Here it is, in all detail:
http://www.jhaible.de/sonofstormtide/sost_sch7.pdf
JH.
numbertalk
PostPosted: Mon Jul 12, 2010 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed I swear I checked and totally missed this. My bad. Thanks!
JH.
sduck
PostPosted: Thu Jul 29, 2010 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I may be going blind. Quick question - the BOM lists 13 1N4148 diodes, but I can only find spots for 12 of them. Am I missing one somewhere?
Also, the GE diodes - I have 2 kinds here; 1N34A and NTE110A. Which ones should I use? Does it even make a difference?
jhaible
PostPosted: Thu Jul 29, 2010 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably not. It's more likely that I listed one of these 5 cent components too many.
1N34A should be fine. I never tried a NTE110A.
JH.
sduck
PostPosted: Sun Aug 08, 2010 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick question - on the audio wiring doc, which side of the resonance pot is cw?
Also, calibration instructions? Are they available yet?
Edit - oh, found your brief instruction a page back. Just got everything assembled, and it seems to work. May need a bit of minor debugging - I.E. the resonance section doesn't seem to be doing anything yet, but I'm not sure what everything does yet, so it may be something trivial.
Edit a few minutes later - oh, for some reason the resonance on/off switch is backwards. But it works!
sduck
PostPosted: Tue Aug 10, 2010 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got done tweaking the trim pots - and then experimenting for a loooong time. Wow! What a sound this thing can make!
I rechecked my wiring against your audio wiring chart, and am fairly convinced there's a mistake at the resonance on/off switch - although I've made triply sure I have it wired according to your sheet, resonance only works when it's in the off position. Not a big problem, as I'll just reverse the wiring.
I'm still not sure what the Env Mod and Env Release knobs do, but they certainly do some interesting things.
jhaible
PostPosted: Tue Aug 10, 2010 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, you are right about the Resonance switch! I just noticed this - waht is labelled as "on" switches the potentiometer to GND. Must be the "off" position of course.
BTW, your front panel looks beautiful, with this coloured labelling!
JH.
numbertalk
PostPosted: Wed Aug 11, 2010 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I believe that is an envelope follower on the input signal - mod would be the amount to apply and release would be the release of the resulting envelope.
Nice panel! Mine should be arriving from FPE today, plan to start building soon.
sduck
PostPosted: Wed Aug 11, 2010 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Except they also affect the shape of the lfo signal when nothing is plugged into the mod input. So there are 4 knobs affecting the overall lfo shape.
sduck
PostPosted: Wed Aug 11, 2010 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Another question. The bidirectional led - mine doesn't work. At least not like I think it's supposed to. At first I had it wired as per the directions, and it stayed on red the whole time, no matter where any of the knobs were set. So I reversed it, thinking I may have misread the polarity, and now it's stuck on green all the time. Am I misquided in how this is supposed to work? I used the same kind of lumex bidirectional led I used in the FS1a, and it works right in that module.
jhaible
PostPosted: Wed Aug 11, 2010 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
They shouldn't. With Env Mod in ccw position, the envelope should not contribute to the modulation.
JH.
jhaible
PostPosted: Wed Aug 11, 2010 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It's been a while since I designed this - but I can't find a bidirectional LED anywhere. Not in the schematics, and not in the prototype ...
JH.
sduck
PostPosted: Wed Aug 11, 2010 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woops! I guess that was just presumptious, wishful thinking on my part. I guess I just wanted some sort of light show from the led that's hung off the Manual Sweep knob. Sorry!
So, should that led indicate anything besides the unit being powered on? That's all mine does. If that's it, then we're done, everything's working, I'm happy!
jhaible
PostPosted: Wed Aug 11, 2010 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's all it does.
JH.
