Chord help needed
Page 1 of 1 [4 Posts]
steampump
G2 patch files: 14
PostPosted: Thu Jan 27, 2005 12:45 pm    Post subject: Chord help needed Reply with quote  Mark this post and the followings unread
Maybe am i blind ? I have not found the modules or the way to use them .
The question is quite simple.
I play one note and want to split it in 3 or more midi notes and shift up or down each note to make a chord.
The result should be send to 1 osc.
I dont want to make 1 osc for each note.
The idea is to use after the variations for Maj Min 7th etc.
Artworks Music Computer
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Jan 27, 2005 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure how it could be done in the one patch but using two slots its not so complex. See example. Var1 and Var2 select chords.
ChordSyn.prf2
one finger chords
 Filename:  ChordSyn.prf2
 Filesize:  3.33 KB
 Downloaded:  1681 Time(s)
steampump
G2 patch files: 14
PostPosted: Thu Jan 27, 2005 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks g2ian
Have tried the perf and it works fine with a performance. But have you any idea why the notesend does not work when you put it together with the osc. in a single patch
I have changed the channel to "this" and "slotA" , logicaly it should work but allways one single note but no chord. or note shift Question
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Jan 27, 2005 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
steampump wrote:
Thanks g2ian
Sending the note to your own slot creates a feedback loop, see
http://electro-music.com/forum/topic-4574.html
