Voltage Meter Module (incl. cable tester)
Page 1 of 1 [10 Posts]
PostPosted: Mon Aug 02, 2010 12:55 am    Post subject: Voltage Meter Module (incl. cable tester) Reply with quote  Mark this post and the followings unread
this is what i did as a fun project last week: a voltage meter module with cable tester. the range is selectable from 0V to 10V or -5V to +5V. the module provides two LEDs indicating the input signal exceeding the modules working range.
to use the spare front panel space i added a cable tester. for this tester the sockets have to be isolated from the front panel (COM).
[for 12V operation R9 and R10 have to be adjusted. this voltage divider sets the reference voltage of 10V for the comparator.]
Voltage Meter Schematic
[edit: pictures embedded]
TekniK
PostPosted: Mon Aug 02, 2010 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
wave
macumbista
PostPosted: Tue Aug 03, 2010 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! What's that crazy thing at the right side of the power rails? 057-010-1...what company is that a part number for? Headers? Some kind of switch?
macumbista.net
PostPosted: Tue Aug 03, 2010 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
haha, no! it is nothing but the small doepfer style 2x5 pin buss connector (ribbon cable).
macumbista
PostPosted: Tue Aug 03, 2010 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thought is was something like that...
macumbista.net
PostPosted: Tue Aug 03, 2010 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
added some nicer pictures:
Tim Servo
PostPosted: Tue Aug 03, 2010 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful work!
Smile
Tim (man of few words, today at least) Servo
PostPosted: Thu Sep 09, 2010 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
i think this thread should now be moved into the fonik's place. janitors?
slo
PostPosted: Thu Sep 29, 2011 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
A couple of questions on the meter itself. Is it a 0-10v range meter, one of your pics shows a 0-30v range meter, also the extra wires going to the meter, is that for illumination?
Thanks in advance
PostPosted: Thu Sep 29, 2011 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
it is 0V>10V / -5V>+5V meter. there is one computer graphic showing 30V, just because i used a picture from the suppliers catalogue to create it.
Thanks in advance
correct. connector J5 interfaces with the actual meter unit, and the 15V feed the light bulb.
