+/- 12V vs. +/- 15V power supplies.
Page 1 of 1 [9 Posts]
OW
PostPosted: Thu Dec 30, 2010 8:50 am    Post subject: +/- 12V vs. +/- 15V power supplies. Reply with quote  Mark this post and the followings unread
Is there much of a difference using +/- 12V as a pose to +/- 15V power supplies for modules?
I ask this because in the past I have previously used +/- 12V, however the current modules I am building require +/- 15V and I am unable to find a reasonably priced 15V AC/AC PSU in the UK. (If anyone could point me in the right direction of one, that would be great).
I use the MFOS wall wart power supply board to power my modules, and this time I am using 7915 and 7815 voltage regulators to power my 15V modules I am currently building. Would I be able to substitute in a 12V AC/AC power supply as I cannot seem to find a 15V AC/AC power supply?
decaying.sine
PostPosted: Thu Dec 30, 2010 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
The power-one and condor supplies can be trimmed to 12 or 15 VDC. You can find 3 amp ones on ebay for as low as $40 sometimes.
Some modules are fine with 12 or 15. Usually they will state this if it is the case. For example, some CGS and Ian Fritz designs run okay on both or run fine with small modifications.
prgdeltablues
Audio files: 12
PostPosted: Tue Jan 04, 2011 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Try Farnell -part number 1217073. It's a 15VAC output linear wall-wart. Only 500mA, but that should power a few modules. Euro mains plug, so you'd need a travel adaptor!
Or CPC (which is linked to Farnell) part no. PW00163 - looks like a UK plug
http://cpc.farnell.com/stontronics/ac-1550/plug-in-psu-15-vac-500ma/dp/PW00163
Peter
sonic
PostPosted: Fri Apr 15, 2011 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Friends,
My local surplus store has these Power One MAP110-4300 +3.3V/+5V/+-12V PSUs for $12.99 a pop. I'd really like +/-15V. Does anyone know if they are they likely to have parts to convert to +/-15V output?
Assuming this is possible I'll need to build it into an enclosure, switch, fuses, AC socket / cord etc too. I'd also really appreciate any advice or resources on how to do this.
Richard
MAP110-4011.pdf
 Filename:  MAP110-4011.pdf
 Filesize:  282.68 KB
 Downloaded:  209 Time(s)
Clack
PostPosted: Fri Apr 15, 2011 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
HEy!
posting this for reference
http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY.php
You can get away with a higher voltage AC wall wart
I am currently using the Rapid 24V AC wall wart to make +/-15v which is overkill but just like you I couldn't get one high enough.
the voltage stated is RMS so to get the peak voltage the regulator will get you do
24 x 1.414 (this is a magic number that converts it) = 33.94V
it will be a bit lower after filtering etc so each regulator will get probably 30v or so and they cut the voltage down to 15v. I checked the LM7915 datasheet and the LM7815 and they say that it can take 35v maximum so its safely within the limit.
it gets quite warm but not hot, I am powering a soundlab so I cant say more about how hot it gets at higher loads but it shouldn't be that bad below 500mA
Clacktronics.co.uk
Appliancide*
PostPosted: Fri Apr 15, 2011 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Richard Goulstone wrote:
Hello Friends,
Richard
This is a switching power supply, so probably not ideal for synth use. Several manufacturers are coming out with switching supplies for modular use, but they are using newer components with faster switching frequencies.
http://appliancide/blogspot.com
sonic
PostPosted: Fri Apr 15, 2011 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah it's switching. That's probably a no go then. Thanks for pointing that out, *Appliancide*.
Thanks Clack. Yes, I know of the MFOS Wall Wart supply. I have a stripboard layout from someone here. Uncle Krunkus perhaps? I plan to build one. I have some caps on order to do just that. No 15V AC wallwart yet though.
Let's face it though, wall-warts aren't the most aesthetically pleasing or elegant solution, are they? For a modular, I would far prefer to build my supply into the cabinet.
The Power One and Condor HAA15-* seem to be the goto supplies for synth builders here. I can't find one shippable to Canada at a reasonable price though. I could roll my own with transformer etc, but I'd take so long over it I'd have no time to work on anything else for a month.
Curses. Maybe I can't have my cake and eat it. Or can I?
vladosh
Audio files: 51
PostPosted: Sat Apr 16, 2011 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
hi all ..
Just thought i'd ask .. since i had so many troubles with a PSU already ..
I found a PSU from an old printer giving -/+ 12 and ground .. now this PSU is working fine comparing to the one i used before .. but i've been told it's a switcher supply and reading the post .. just thought i'd ask .. do i risk something using a switcher supply ?
thanks a lot
greetings
vlad
Audio files: 297
PostPosted: Sat Apr 16, 2011 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
You dont really risk anything with a switching mode power supply, the switching may cause some audible artifacts, thats all. You may be able to filter that out, having a proper star grounding will help too to avoid such problems.
When using a computer supply ... those are able to deliver a lot of current ... which means that when you make a mistake with the wiring some stuff may go up in smoke ... you could use fuses for experimenting though.
