today> Various Artists September equinox Concert
New user with temperamental machine
Page 1 of 1 [5 Posts]
Mefistophelees
PostPosted: Sun Mar 06, 2011 4:14 pm    Post subject: New user with temperamental machine Reply with quote  Mark this post and the followings unread
Hi all,
Recently got myself an A6. It's in very good condition the sounds is just phenomenal!
However I've noticed in the last few days the front panel controls have been a bit intermittent, some not responding much if at all.
I've been moving it about a bit so I'm wondering is something working itself loose.
Is this a known problem, or should I be digging out the screw driver and reseating the connectors?
Mefistophelees
PostPosted: Mon Mar 07, 2011 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, so I tried it now. I fiddled around with the global controls a bit and suddenly the controls came back to life... weirrrrd!
Are they always this temperamental?
CoolColJ
PostPosted: Mon Mar 07, 2011 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know at one stage the controls would jitter, even just one pot doing that would make the whole machine act erratic.
I believe there was one OS update that attempted to fix it
Just go through each pot and give it a twist to clear it up
Mefistophelees
PostPosted: Tue Mar 08, 2011 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
It had started working again but not quite perfectly. I took your advice and low and behold it seems to be just fine.
sunny pedaal
Audio files: 12
PostPosted: Fri Mar 11, 2011 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
i sometimesclean the synth's with a vacuumcleaner.
do a nylonstocking around the pipe just to make sure no bigger parts or knobs are suck in too.
this works out very fine to clean the pushingbuttons etc , at least for me.
plus i always use a dustcover when not using
