Troubleshooting the VCLFO (1)
Page 2 of 2 [34 Posts]
Goto page: Previous 1, 2
PostPosted: Fri Apr 29, 2011 5:33 am    Post subject: Re: Just built two VCLFOs Reply with quote  Mark this post and the followings unread
kkissinger wrote:
Also, on the LOW frequency range, I get a large offset voltage. Anyway, once I get non-polarized in place I hope this takes care of the symptoms.
Just to follow up: I reviewed the schematic and found that I had missed that the VCLFO has separate offset adjustments for the low and high ranges. Thus, the offset problem was nothing more than a trim adjustment.
Thus, the only outstanding issue is the sync issue -- not a huge issue and could almost be a "feature". Smile
kupfer_m
PostPosted: Mon May 02, 2011 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
yusynth wrote:
LektroiD wrote:
The spikes are really obvious through a VCF or VCA. Any way to tame them?
Try and change the tantalum cap until you minimize the glitch.
I have the same problem with my VC-LFO2. But I also get spikes on the x1 setting. Will try with some other capacitors.
LektroiD
PostPosted: Wed Jun 29, 2011 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
did the other capacitors work?
Just a thought, this thread could maybe merge with the other VCLFO one, since it's the same issue
LektroiD
kupfer_m
PostPosted: Wed Jun 29, 2011 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
No, still those nasty clicks...
Tried a MAXIM 7555 (more expensive) but still the same.
One day I will find it Wink
vinnui
PostPosted: Mon Jul 04, 2011 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm building 3 VC-LFO-2s, and today i've checked the waveforms of my first LFO build. The spikes were here. I've found, that i've used a NE555, which i've replaced with a ICM7555CN (I think it's a Philips part). After a complete recalibration procedure, the spikes are gone.
adambee7
PostPosted: Mon Jul 04, 2011 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
ive noticed on the schematics that there is no current limiting resistor going to the power pin of the 555. Would this be worth adding. usually its 100ohms. Very Happy Very Happy
yusynth
PostPosted: Tue Jul 05, 2011 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
This is only valid if one uses the non CMOS version of the 555 ! Here we are using a CMOS 555 and this resistor is of no use.
Yves
adambee7
PostPosted: Tue Jul 05, 2011 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks yves Very Happy . now to find some phillips 555. Very Happy Very Happy
gibrancurtiss
PostPosted: Sat Apr 08, 2017 6:57 pm    Post subject: changed C5 Reply with quote  Mark this post and the followings unread
Changed the C5 from 47pf with other values 470pf and 1K.
47pf C5
 Filesize:  158.32 KB
 Viewed:  355 Time(s)
47pf C5 zoomed to 50us
 Filesize:  122.59 KB
 Viewed:  362 Time(s)
1k C5
 Filesize:  153.44 KB
 Viewed:  313 Time(s)
1k C5 zoomed to 50us
 Filesize:  138.84 KB
 Viewed:  339 Time(s)
