receiving error
Page 1 of 1 [12 Posts]
flying rabbit
PostPosted: Tue Aug 16, 2011 11:39 am    Post subject: receiving error Reply with quote  Mark this post and the followings unread
I have got a problem with one of my NL3. When trying to dump a performance from NL3A ( version 1.04) to NL3B ( version 1.20) I get the message " receiving error" The other way B to A is no problem .
What is this? Is it that you cannot import from a new OS but you can from an older to a newer?
I don't understand this
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 16, 2011 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks to me your post is telling the opposite ways of uploading... Shocked
There is backwards comptability, which means you can use old versions (V1.04) into the newer one (V1.20)
Wout
flying rabbit
PostPosted: Wed Aug 17, 2011 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
So that means my suggestion is right...?
there is no compatibility from the newr to yhe older?
Or not?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Aug 17, 2011 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
No new to old.
Yes old to new.
As soon you save it in the new one, it can't be uploadedback.
But you can upgrade V1.04 into V1.20.
Wout
flying rabbit
PostPosted: Thu Aug 18, 2011 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah!!! that sounds interesting.
As I am to lazy to read about it - how to go ahead with that then...ofcourse without erasing the current performances..
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Aug 18, 2011 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, save those before then Smile
I'll read you again when finished!
Wout
flying rabbit
PostPosted: Mon Aug 22, 2011 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
I am still hanging on to this problem. After having tried to download the patches and performances to my new bought p.c. - bought just for this purpose ( I am usually mac oriented) with the downloaded program "Nord lead 3 sound manager version 1.02" - which after down loading says only available for version 1.20 the pc crashes. I tried to dump the programs from my version 1.20 but the system crashes repeatedly. To dump the programs form version 1.02 is not working at all.
So next issue would be - is there any other program to use in order to down load the version 1.02 ( and version 1.20) to a p.c. . Is there any known conflict with that program ( NL3 sound manager) with other windows programs ( I have no other program installed than the default - not even internet connected) .
Grateful for any input
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 23, 2011 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you send me one or two of those V 1.02 Programs?
Post them here as attachment.
Wout
flying rabbit
PostPosted: Tue Aug 23, 2011 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure if this works but the program was downloaded frm
www.nordkeyboards.com/main.asp?tm=Downloads&cldwn=Nord_Lead_3&osdwn=osw
It says version 1.02 but looks like be version 1.20
flying rabbit
PostPosted: Tue Aug 23, 2011 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
no it did not work I was not allowed to forward the extension but the website is the same file
PostPosted: Tue Aug 23, 2011 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Which extension was it? I may be able to add it.
flying rabbit
PostPosted: Tue Aug 23, 2011 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was the flle as in the bebadress above but downloaded to my pc
