change LFO +/- modulation to + only (like ADSR)?
Page 1 of 1 [6 Posts]
Ojd
PostPosted: Wed Sep 14, 2011 2:26 am    Post subject: change LFO +/- modulation to + only (like ADSR)? Reply with quote  Mark this post and the followings unread
hello. I've build LFO for my synth, but i'm somewhat disappointed with the overall feel. +/- modulation feels very unnatural to me (+5V/-5V), + only modulation (like 0/10v) would be much preferred. Bipolar modulation on VCA really annoys me, as i cannot fade tremolo slowly using only LFO output attenuator. So is there a way to change that? I'm sure there is - i just need to offset LFO's output, right? (but I need schematic)
bubzy
Audio files: 64
PostPosted: Wed Sep 14, 2011 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
what LFO did you build? do you have a schematic for it? this might help a bit.
Tim Servo
PostPosted: Wed Sep 14, 2011 11:05 pm    Post subject: change LFO +/- modulation to + only (like ADSR)? Reply with quote  Mark this post and the followings unread
Hey Oj,
There are a couple of different ways to do this. I did a search for for "non-inverting op amp with offset" and came up with a circuit that I tweaked for +/-5V in and 0 to +10V out. This should get you pretty close. Wink
Tim (tweaked) Servo
 Filesize:  26.14 KB
 Viewed:  190 Time(s)
Thomas_Henry
PostPosted: Thu Sep 15, 2011 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Gang,
Let's get rid of a resistor. See the attached schem.
Actually, you can get it down to only four resistors if you're willing to put up with odd values. The five resistor version shown here uses very ordinary values however and is dead-on for accuracy. You'll all recognize it as a variation of something which appeared in my VCO Chip Cookbook.
But if your original LFO is of the Schmitt trigger/integrator type, then you can jettison all of this and get what you want with no additional parts. That topology lets you easily set the center line and amplitude. I did this recently in a new VCO design in which I needed a 0 to +5V output---I changed a few resistors and away I went!
Thomas Henry
Reduced Parts Count Version
 Filesize:  62.78 KB
 Viewed:  178 Time(s)
Ojd
PostPosted: Fri Sep 16, 2011 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you all for the reply.
Here's the schematic.
And output voltage is not 5v bipolar.
But i've found this: http://www.musicfromouterspace.com/ELECTRONICBUBBLEGUM/TOOLBOX/toolbox.html
(thanks Servo for the keyword tip, didn't know how to put it into google)
For the lfo inversion doesn't mean much, so i'll stick with MFOS version (though i need to reverse LED on the panel)
Thomas_Henry
PostPosted: Sun Sep 18, 2011 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi again,
Okay, here's the usual Schmitt-trigger/integrator with the comparator input offset as I mentioned earlier. As shown, this will put out a 0 to +10V triangle instead of a +/-5V signal. The alteration is easy and if you really need precision for the baseline, just replace the divider with a trimmer.
As I guessed, the circuit the original poster asked about is of this type. Obviously, this mod can be done with the Woollaston schem posted above. But Peter Lutz's original circuit, which predates the one above, is more versatile since it allows variable offset. You'll find it in Electronotes, Volume 10, Number 88, April 1978, pp. 24, 25.
By the way, the LFO shown here has a 1000:1 range which I suspect is greater than either the Lutz or Woollaston circuits.
Thomas Henry
0 to +10V LFO
 Filesize:  137.52 KB
 Viewed:  196 Time(s)
