ASft21C _ ADSR and others... TL071 question
Page 1 of 1 [5 Posts]
marvkaye
PostPosted: Sun Oct 02, 2011 7:04 pm    Post subject: ASft21C _ ADSR and others... TL071 question Reply with quote  Mark this post and the followings unread
Regarding the TL071 used in the ADSR from Thomas' Synth for the 21st Century... is it necessary / required / desirable to ground or otherwise terminate the input offsets (pins 1 & 5) or can they simply be left to float? I didn't see anything mentioned in the datasheet but I confess that I may have missed something, even if it was there. Your thoughts??
<marv>
bubzy
Audio files: 64
PostPosted: Sun Oct 02, 2011 11:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/post-94183.html
might clear it up a little, from looking at a few pages it doesnt seem necessary
marvkaye
PostPosted: Mon Oct 03, 2011 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the pointer to that thread.. I thought I remembered reading something about it here somewhere. I also recollect the general admonition that said unused pins on certain chips needed to be grounded and was wondering if this was one of those cases. It looks like apparently not.
<marv>
Tim Servo
PostPosted: Wed Oct 05, 2011 2:25 pm    Post subject: ASft21C _ ADSR and others... TL071 question Reply with quote  Mark this post and the followings unread
Hey Marv,
In most cases the offset is so small that you don't need to worry about it, and you can leave those pins unconnected.
What you may be thinking of are CMOS inputs. THOSE should never be left unconnected or "floating." Hook them to +V or GND instead. While it's probably not a bad idea to ground unused op-amp pins, it's not absolutely necessary.
Tim (ground round) Servo
marvkaye
PostPosted: Wed Oct 05, 2011 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim (typically parenthetical variable mid-nomenclature) Servo,
Thanks for the tip. I've stripboarded this guy and am ready to start testing... I'll see if clipping those offsets to ground has any noticeable effect and can always solder in an extra connection or two if required. I'll try to remember the admonition about CMOS, though... at least I knew something was not supposed to be left hanging. Wink
<marv>
