Confused about MPS jack socket requirements
Page 1 of 1 [4 Posts]
slowalan
PostPosted: Thu Dec 15, 2011 4:25 am    Post subject: Confused about MPS jack socket requirements
Subject description: Advice please?
The MPS calls for both no and nc switching jacks....I cannot source the normally open type...can I just use a two pole non switched socket instead of the normally open switched one? Or how do I achieve this with available jack types?
It seems that manufacturers do not commonly use the "normally open" or "normally closed" terminology...so I would very much appreciate advice and maybe a link to the correct type on Mouser or another supplier.
With thanks
slowalan
jumunius
PostPosted: Fri Dec 16, 2011 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Switchcraft 502-112AX for one. There is a group buy over at Muff here. I don't know if it's open to Australians, but there's a Mouser link at least.
You can buy good quality knockoffs of these jacks from Bridechamber.
Personally I just buy all normally-closed jacks and then I don't have to think about it. They are "normally open" if you simply ignore the switching lug.
-Jim
jumunius
PostPosted: Fri Dec 16, 2011 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
PS I think I read your question backwards. "Normally open" is just a standard TS jack. Normally open means that when nothing is plugged in, the lug associated with the tip does not complete a circuit.
-Jim
slowalan
PostPosted: Fri Dec 16, 2011 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks Jim...confusion resolved!
